58mm holley throttle body
Old Jan 19, 2007 | 11:21 AM
96camaroz281988's Avatar
does any one now what the CFM for a 58 Holley throttle body is off the top of there heads
Old Jan 19, 2007 | 11:32 AM
BUBBA's Avatar
I believe around a 1000----do the math.
Personally, I would not go with a Holley. JMHO
Old Jan 19, 2007 | 11:41 AM
BUBBA's Avatar
make that 1050...
Old Jan 19, 2007 | 11:55 AM
Jlo's Avatar
Jlo
Why not, their are alot of people runnng holleys without problems.
Old Jan 19, 2007 | 12:55 PM
BUBBA's Avatar
So...if there are alot of people running them without problems, then there are apparently some people who have experienced problems....so why would one take a chance on being one of those people who have experienced problems?JMHO
Old Jan 19, 2007 | 01:02 PM
arcticz28the383's Avatar
I have a 58mm holley. No problems yet.
Old Jan 19, 2007 | 01:15 PM
2000GTP's Avatar
People have had issues with the other brands of throttle bodies as well, not just the Holley line.
Old Jan 19, 2007 | 01:27 PM
BUBBA's Avatar
Ok: what part of "personally I would not go with a Holley"........
Just kidding----actually, several members have experienced problems with the Holleys, wheresas I have not seen as many complaints about other TBs including AS&M, BBK, etc. The only reason I mention the Holley, per se, is that several members have opted for the Holleys because they look so pretty and all with their red butterflys-----but who looks at the red butterflies when you can't even see them with the plenum attached.
If you want a Holley, get a Holley.
Old Jan 19, 2007 | 01:33 PM
BUBBA's Avatar
oh....actually the problems with the Holleys (that I have seen on this board) have more to do with initial installation, i.e, at least some people were not able to plug and play and had to make some adjustments, etc.
So apparently it isn't a matter of something going wrong with them later, just some initial issues. So, I decided that for that much money I would opt to go with a TB with a reputation of plug and play---no screwing around. JMHO
Old Jan 20, 2007 | 09:46 AM
Brent94Z's Avatar
Super Moderator
This is what I've seen too.
I've had/have BBK, Holley, and AS&M. My AS&M bolted up no problem and I haven't had a problem with it for the 10 years ( ) it has been installed. The Holley I had trouble with the cruise control cable "stud" in that it had too thick of a head and the factory piece wouldn't fit. A Dremel and about 2 minutes fixed the problem. Others have had problems with the blades not fully sealing (like they installed 52mm blades ina 58mm TB! DOH!). Since then I've had zero issues with the Holley.
The biggest issue with a 58mm throttle body is for people with the 4L60E. Those who have a 58mm tb and 4L60E really should have the PCM reprogrammed to account for the lower TPP for the same driving speed/habits around town.
If I was going to buy a 58mm throttle body right now I'd buy either a Holley or AS&M and then I'd buy which ever I could get the best deal on
Old Jan 20, 2007 | 10:06 AM
dannyum89's Avatar
Theres problems with the BBK also. It sticks open when you spray in it and also sticks open on its own without reason. Also the way that the idle air ports are fabricated is not even close to the stock TB which sometimes causes ideling problems. I think all aftermarkets are made that way though.
Old Jan 20, 2007 | 10:17 AM
Denny McLain's Avatar
The famous syndrome supporting purchase decisions:
"I've not had problems, therefore anyone whom did, didn't know what they were doing as I bought the best."
Kills me everytime. Welcome to the internet girls, where rocket science and logic merge in perfect union.
Old Jan 20, 2007 | 12:40 PM
make that 1050...
A flow number, without a corresponding pressure loss number, is totally meaningless.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
kaoticcamaross
Feb 17, 2015 03:13 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
