500+ Rwhp
Old Mar 11, 2006 | 09:36 AM
  #151
PNYKILR's Avatar
From: Albuquerque,NM--5,600 feet above you sea-level cats
Re: 500+ Rwhp
Originally Posted by SStrokerAce
PNYKILR,
How much idle vacuum do you have?
93SS is working on a 500rwhp setup as well.... we will know soon how much the motor makes alone.
Bret
Not sure. Never checked it. I'll get back to you on that. The cam is a 270ish@.050, 690ish lift on a 108ls. By no means a street friendly cam, but you guy's know that. Thing is I don't mind it.
Old Mar 11, 2006 | 11:30 AM
  #152
93SS's Avatar
Re: 500+ Rwhp
Like I said before, you have one WICKED ride. Great work.
Old Mar 11, 2006 | 12:31 PM
  #153
PNYKILR's Avatar
Re: 500+ Rwhp
Thanks. 500 gets boring after awhile. As Always I want more power, and a new project is in the works. My pocket book is just not deep enough to suport two car's but that's what I'm doing. Bought a 86 t-top mustang. Car is gutted. Motor and trans are about to go in. Turbo is a 76mm. I've got everything, just need to make adjustments on the turbo system(one that I built and still fabbing up the piping). Hope to have it running a month from now. Goals for this car??? I don't know. Something that runs bottom tens here or better. Wont see a whole lot of track time though. Want to drive this one around and have fun. Only mustang I've owned so a turbo project sounded good. Hell, depending on how it runs I just may turbo the TA.
Neal
Old Mar 11, 2006 | 05:09 PM
  #154
marshall93z's Avatar
Re: 500+ Rwhp
I don't suggest the stock block!
Old Mar 11, 2006 | 05:31 PM
  #155
Z28LT1_Just_Nasty's Avatar
Re: 500+ Rwhp
Mod make this a sticky please!
Old Jun 2, 2007 | 12:34 AM
  #156
CANTONRACER's Avatar
I just wanted to update my "500 rwhp" combo...first trip to the dyno made 433.4/464.5 STD @ the wheels.
That is with a TH-400, non-locking nitrous converter, Moser 12 bolt, Denny's nitrous ready driveshaft and MT ET Streets.
I never thought my drivetrain would be so power robbing...I am sure the car will run very well, but dyno number wise it was killed. Figure in a 28% drivetrain loss.
Now I can get another 20-30 rwhp out of the combo by fixing some bugs, but 500 rwhp with my drivetrain with my motor is not going to happen (and I have a stout setup).
How easy it is to say I have 500 rwhp....
Old Jun 2, 2007 | 04:50 AM
  #157
97SS0594's Avatar
im happy with my 300 or so rwhp car then add a 300 shot
Old Jun 2, 2007 | 07:01 AM
  #158
Denny McLain's Avatar
Originally Posted by Mindgame
Interesting point Ryan.
For all the talk of how easy it is, I don't see many doing it. Then again... if you have a 330 cfm head it's always good to know that you "should" make 700 hp. After all... that's what the program says right? It's all the stuff that wasn't mentioned that takes that out of the "real world" for 99.9% of the people on this board.
-Mindgame
I agree 100% with that.
Almost 13 to 1 compression, TF heads that flow well over 300 cfm, a sheetmetal intake and busting my ***** for years working out the little stuff to get to 500 rwhp. According to everything on paper the car should easily exceed 500 rfwhp. So far it ain't happened.
The car is sitting in the garage right now being put back together after realigning the intake bolt openings, replacing a .015 head gasket, resealing the intake differently and relocating the 02 sensors in the headers.
Get the biggest kick out of people giving advice on how to get 500 rwhp from a streetable LTx motor who have never come close. Putting numbers and combo together on paper or using software is one thing, actually making it work is another.
If I knew how, I'd tell ya....... obviously I don't, but I'm working on it.
Old Jun 4, 2007 | 08:32 AM
  #159
N20Dave's Avatar
I have an update: After going through some bottom end bugs and changes we got it in the car and made some pulls. The new engine dyno numbers were 710 hp as we changed a few things to make it more nitrous friendly.
It made 589 rwhp and 505 rwtq. this is through a Gforce 6speed and a 12 bolt.
Idle was at 950, vac however was about 9".
Old Jun 4, 2007 | 09:56 AM
  #160
SS MPSTR's Avatar
Impressive as hell. Great job. God is not only in the details, but in the heads and pocketbook too
Old Jun 4, 2007 | 08:17 PM
  #161
FASTFATBOY's Avatar
Why not, Rick Intrau made 1200 RWHP with the stock block....I think it will be ok for 500 rwhp.
David
Old Jun 4, 2007 | 08:36 PM
  #162
hsyr's Avatar
David
I think he was refering to the mustang
Old Sep 19, 2007 | 01:57 PM
  #163
Tokuzumi's Avatar
Build a 396 with these heads. They used to make them for the LT1, under the Dominion brand name. You would need custom pistons, at a minimum. I sold my set to a guy, who's name I forgot, but he posted on this board with the name of "TheBigShow".
http://www.araoengineering.com/
RUENUF
Mar 13, 2016 03:37 PM
95chwagon
Oct 16, 2015 12:24 PM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
