500+ hp?
Old Feb 7, 2004 | 08:14 PM
93camaroLT1's Avatar
500+ hp?
looking to swap out my motor for a big block setup, how big of a engine will fit under the hood of my 93 Z28? i want to run a carbuerated set up with a crate motor, has anyone done this? how much am i looking at spending to run a crate motor with around 475-510 hp at the crank. assuming i can purchase the motor for around 3 grand?
Old Feb 7, 2004 | 08:17 PM
Josh-'04 GTO's Avatar
Where can you buy a 500 horse crate motor for $3K?
A big block will fit just fine...I think it was Brady96Z that did a 9.55 with his first time out!
Old Feb 7, 2004 | 11:29 PM
badblackta's Avatar
why do you want a big block in your camaro? when you could just buld your lt1 mildly with forged internals, ported heads, a cam, and alot of nitrous and beat the crap out of a big block. plus that is alot of weight, power to weight ratio. small block 500 hp will beat a big block 500 hp because of the added weight of the big block. I f you really want to, bmr fabrication makes a k member for putting a big block in a 4th gen.
Old Feb 8, 2004 | 12:17 AM
S.J.S.'s Avatar
I agree with BigBlack. You will have a biyatch of a time trying to get that badboy in there also. It will be a lot easier to just build a 383 or 396. Spend the extra money on an awesome set of heads. Thats where the power is.
bossco
Nov 29, 2014 10:18 AM
Z28LT1_Just_Nasty
Sep 19, 2007 01:57 PM
stereomandan
13
Jul 25, 2006 05:44 PM
JS02
May 5, 2006 11:22 AM
25THRSS
N2O Tech
Jan 13, 2005 11:20 PM
