4bolt lt1 ?
Old Mar 10, 2007 | 09:15 PM
transam001's Avatar
4bolt lt1 ?
i have a 95 ta. i put a lt1 out of a vette.. i pulled it out this winter to rebuild it and it was a 4 bolt main.. is this a lt1 or lt4 motor. i put down 288hp with a 3000 stall and 273 gears. all rest factory... any input..
Old Mar 10, 2007 | 09:28 PM
bingo's Avatar
The vettes got 4 bolt mains. I don't know what the differences in the LT1 and LT4 other than the heads and intake.
Old Mar 10, 2007 | 09:31 PM
transam001's Avatar
it had a red intake, but i think that someone painted it..
Old Mar 10, 2007 | 09:32 PM
xsk5's Avatar
if i'm not mistaken 6 speed corvettes had 4 bolt main lt1s. an easy check is the color of the intake manifold, red=LT4.
edit* the LT4 also has roller rockers instead of the ball-fulcrum type.
Old Mar 10, 2007 | 09:51 PM
Corvettes got 4 bolt main blocks.
Old Mar 11, 2007 | 11:20 AM
As Shoebox noted ALL Corvettes, 92-96, got 4-bolt main LT1 blocks. There is no difference between an LT1 and an LT4 block. If you want to check if it came from an LT4 (all 96 M6 Corvettes), compare the part numbers to this list:
http://www.malcams.com/legacy/misc/LT4.htm
Old Mar 11, 2007 | 11:37 AM
transam001's Avatar
thanks alot guys, just a lt1.
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
