431rwhp/386rwtq - TEA LT1 heads/custom cam
Old Nov 21, 2006 | 04:32 PM
  #31
speed_demon24's Avatar
Originally Posted by Jason99T/A
Thunder's SuperFlow 1020 bench is a bit on the conservative side. It is ~15cfm lower than TEAs at peak. TEA also flow their exhaust with a pipe; the exh. flow numbers listed in the first post is w/o a pipe.
Yeah I know about the pipe I was just curious. Anyway flow #'s don't mean **** when you put down over 430rwhp. How would that cam be for a daily driver?
Old Nov 21, 2006 | 05:36 PM
  #32
Jason99T/A's Avatar
It honestly is not that bad. It's a little lacking below 3500, but comes on very strong past that. The 4:10s help too. I wish we could have run a bit more compression in the motor (closer to 11.8:1 vs. the current 11.0:1), which would have helped a good bit with that. However, we were on a very tight scheule and ran out of time to get the heads milled a bit more, so we just had to leave it be. We don't plan on keeping this motor in there too long - she really wants to build a 383 in the summer.
Old Nov 21, 2006 | 07:50 PM
  #33
LT4POWR's Avatar
It's good to see that you guys are still messing around with the ol’ LTx motors too.
Old Nov 21, 2006 | 08:50 PM
  #34
seawolf06's Avatar
Do you think 11.8 would be too much for pump gas even on AL heads? I'm gonna want as much as I can run safely. Allan should be able to tune it for whatever I'm running anyway, right?
Old Nov 22, 2006 | 01:00 AM
  #35
trax's Avatar
Jason,
I didn't see the MAF setup mentioned in your original post. Is it an LT1 MAF? LS1? Z06? Ported / descreened or stock?
Thanks!
Old Nov 22, 2006 | 09:59 AM
  #36
Jason99T/A's Avatar
Originally Posted by trax
Jason,
Thanks!
It's a screened, stock LT1 MAF.
Jason
Old Nov 22, 2006 | 10:04 AM
  #37
PurplePonyEatr's Avatar
Originally Posted by BlueCamaroZ28
Nice #'s but maybe too much for a girl to drive! j/k..
not for this girl!
natalie
Old Nov 22, 2006 | 10:55 AM
  #38
Kraest's Avatar
Retired
11.8:1 would be fine. That's what I was running on my old 396 LT1.
Anything under 12:1 should be easy enough to tune on 93.
Allan is magic.
Old Nov 22, 2006 | 10:57 AM
  #39
Kraest's Avatar
Retired
Jason, is it safe to say that Futral tuned it?
Old Nov 22, 2006 | 11:01 AM
  #40
Kraest's Avatar
Retired
Originally Posted by PurplePonyEatr
not for this girl!
natalie
Get On It!
Old Nov 22, 2006 | 05:19 PM
  #41
The dyno graph (right click | open link)
http://i120.photobucket.com/albums/o...yeatr/dyno.jpg
Old Nov 22, 2006 | 05:27 PM
  #42
marshall93z's Avatar
Looks like the power is holding steady too!
Old Nov 22, 2006 | 08:30 PM
  #43
Zigroid's Avatar
very nice power
Old Nov 24, 2006 | 12:48 PM
  #44
Jason99T/A's Avatar
It pulls like that all the way to the 7k limiter! It feels like it never stops pulling!
Old Nov 24, 2006 | 03:34 PM
  #45
seawolf06's Avatar
So where are you gonna set the shift light at? I know you built that motor to go well past 7k!
