431rwhp/386rwtq - TEA LT1 heads/custom cam
They are ~25lbs heavier than a 12-bolt and slightly less efficient, and very overkill for what she will be doing. I have had very good luck with 12-bolts being very durable and staying quiet when setup corretly.
Thunder's SuperFlow 1020 bench is a bit on the conservative side. It is ~15cfm lower than TEAs at peak. TEA also flow their exhaust with a pipe; the exh. flow numbers listed in the first post is w/o a pipe.
I don't think the stock rear is going to last too long.....
And whats the runner size on those heads?
