431rwhp/386rwtq - TEA LT1 heads/custom cam
Old Nov 20, 2006 | 03:54 PM
  #16
Heatmaker's Avatar
Advanced Member
Originally Posted by LT4POWR
maybe Comp, but probably CamMotion
\I'd say Comp, that's the box my stuff came in.
Old Nov 20, 2006 | 06:01 PM
  #17
speed_demon24's Avatar
Originally Posted by Jason99T/A
The cam specs are correct!
Thanks for the congrats, everyone!
Damn nice #'s, I might have to call you guys up when I get my new set of heads.
Old Nov 20, 2006 | 07:20 PM
  #18
neil350's Avatar
Nice numbers, I have seen a few cars on there make 415-420rwhp with 100K on the stock short blocks, so a new short block, makes sense.
Old Nov 20, 2006 | 07:21 PM
  #19
redneck01's Avatar
nice #'s..i wish i had an m6 and 10 bolt to free up some power for the dyno. j/k. nice setup
Old Nov 20, 2006 | 07:24 PM
  #20
seawolf06's Avatar
Pretty sure it's Comp. FMS uses Cam motion for sure.
Old Nov 21, 2006 | 01:56 PM
  #21
Jason99T/A's Avatar
Originally Posted by T/A-Bob
Excellent numbers
Is your girlfriend going to be racing this car?
Once we order a 12-bolt, she will be back out there racing. Maybe around Christmas time. I don't think the stock rear is going to last too long.....
The cam is from Comp.
Old Nov 21, 2006 | 02:06 PM
  #22
seawolf06's Avatar
What about a Dana 60 Jason?
Old Nov 21, 2006 | 02:13 PM
  #23
RealQuick's Avatar
Nice #'s!!
  #24
Jason99T/A's Avatar
They are ~25lbs heavier than a 12-bolt and slightly less efficient, and very overkill for what she will be doing. I have had very good luck with 12-bolts being very durable and staying quiet when setup corretly.
Old Nov 21, 2006 | 02:24 PM
  #25
seawolf06's Avatar
I thought since that being stronger and cheaper would give them an edge over the 12-bolt, even though it's overkill. Guess they just aren't proven in F-bodies yet.
Old Nov 21, 2006 | 02:26 PM
  #26
BlueCamaroZ28's Avatar
Nice #'s but maybe too much for a girl to drive! j/k..
Old Nov 21, 2006 | 02:42 PM
  #27
seawolf06's Avatar
Haha, you should race her then...
Old Nov 21, 2006 | 03:00 PM
  #28
If so, then let's delay it till she gets a stronger 12-bolt rear..haha
Old Nov 21, 2006 | 03:42 PM
  #29
Is your bench real conservative or does TEA's read high, the stage 2's are supposed to flow 280+cfm. And whats the runner size on those heads?
Old Nov 21, 2006 | 04:28 PM
  #30
Jason99T/A's Avatar
Thunder's SuperFlow 1020 bench is a bit on the conservative side. It is ~15cfm lower than TEAs at peak. TEA also flow their exhaust with a pipe; the exh. flow numbers listed in the first post is w/o a pipe.
