410 gears? 94 A4
410 gears? 94 A4
hey i got a ques...i got a 94 A4..stock..but im beginning to hear a whining sound in the back when i accelerate..and wheni do a u turn slowly...i can kind of hear the rear end making some kind of scraping noise.i dont know..doesnt sound good tho..im thinking if i change out the gears that would fix it..but not sure..and also if i put in some 410 gears how much do u think that'll take off my 1/4 mile?? thanks
dude...4.10 gears in ur auto will be quicker, but man..u'll be suckin down gas cuz u'll be revvin pretty high on the highway. id go with 3.73. thats what i had in my old '95 z auto. as far as the tight turn whine sound...a bottle of gm limited slip axle lube additive should do the trick. it did for me. it will reduce noise in the rear end.
mike
mike
ya ...my friend as a m6 TA..and he put in 410 grs..he said i should do the same but i understand what ur saying w the a4..but he said taht w the 373 ill barely feel a difference...
i had the 3.23 gears stock and bought an auburn pro series carrier w/ 3.73s. it did make a difference. a few tenths difference. i was surprised myself cuz i had a few friends doubting the gear change wouldnt do much.
I got some Strange 3.73's for the 2 series carrier and a Ratech install kit from Thunder. All together, about $315 shipped. The shop that did the install charged $312 here. I did find shops that'd do it cheaper, but this one in particular had a great rep. YMMV.
Will it solve the noise problem? No idea. It's impossible to say what might be wrong over the internet. If you do get some gears, make sure you let the shop know what's going on, it may be something as simple as needing new gear oil & GM limited slip diff fluid, then again it may not.
Back to the 4.10's - the 3.73's are bad enough with the rpm's cruising @ 65-70. I wouldn't want to deal with 4.10's, personally.
Another thing you might discover (as I did), the higher rpm's might reveal that you have a vibeshaft problem. I never noticed it with the 2.73's, but there's no mistaking it now! I got a custom made steel one from www.pstds.com shipped for $227
Similar in price with the 1LE - but not weak aluminum. It's not here yet, but I'll post when it's in.
prolly your best bet on not having any gear whine is to buy GM gears. they made alot better than any other company u will find. cost a helluva lot more than aftermarket, but u wont have the gear whine. buying a cheap or used gear.......u'll most likely get whine.
With my 4.10's in an A4 head/cam car that runs 12.25, I get 18+ MPG.
I cross the stripe @6100 RPMs, in 3rd gear, at 111 MPH...With 26" tall tires. I cruise at 2300 RPMs, in 4th gear, at 60 MPH.
The 4.10s are good for a 1.67 60 ft. time in a full weight '93 Z with a completely stock suspension, other than the front sway bar removal...On 26"x11.5" ET Streets.
I went from 3.23 to 4.10s and dropped 3/10's...When the engine was completely stock. BTW, the car went a 12.82 @ 106 MPH with a 93,000 mile LT1 that had never had a valvecover off, and still had exhaust manifolds. The only REAL mods were the 3200 stall, and the 4.10 gears.
Frank
Frank
ChrisFrez
Mar 22, 2015 09:12 AM
thanks
