4-Wire O2 Question...
Old Jan 14, 2006 | 08:55 AM
toegead93's Avatar
Okay, I have a new 4-wire O2 sensor and harness. Is the purple wire the ground?
Old Jan 14, 2006 | 11:30 AM
Re: 4-Wire O2 Question...
Purple wire is the "signal" to the PCM. Tan wire is the ground return to the PCM (your 93 will not have that pin in the PCM connector). Pink wire is +12V for the heater circuit. Black wire is ground for the heater circuit.
Old Jan 14, 2006 | 12:22 PM
toegead93's Avatar
My harness has two brown wires and no black or pink so I wasn't sure what was what. Based on the schematic I'm using the outside brown runs to the 12V source, the inside brown is the ground, purple to the ECM and the tan is not used. Thanks.
Old Jan 14, 2006 | 11:13 PM
Conversion to heated O2s diagram:
Normal heated O2 wiring:
Old Jan 15, 2006 | 11:31 AM
toegead93's Avatar
That's the diagram I am using, but my harness isn't marked A, B, C, D so I was a little confused. I think I have it all in order now. Thanks again guys.
Old Jan 15, 2006 | 05:22 PM
Rob:
Why does the conversion drawing show the brown wires for the heater element, while the 95 wiring diagrams on your web page show the black and pink wires for the heater element? I have an old stock sensor in the garage, and it has the brown wires, but I thought your wiring diagrams might be more accurate.
Old Jan 15, 2006 | 11:40 PM
Originally Posted by Injuneer
Rob:
Yeah, I know. I modified the diagram above to match the real world harness plug that I have in the pic. It would have been confusing otherwise .
The PCM diagrams on my page are not modified and show the pink and black wires (probably where you saw it). I guess I should try to be more consistent.
I don't have a clue why the factory diagram does not match the harness colors for those two wires.
Old Jan 15, 2006 | 11:42 PM
If you look closely, the harness plug has the letters molded into it. Most every factory plastic harness plug does. I added the typed in letters for clarity.
Roadart
Jul 25, 2004 09:44 AM
LWillmann
Jul 24, 2004 11:50 AM
Bad AZz Z28
Jul 5, 2004 02:57 AM
RootBreaker
V6 Tech
Jun 8, 2004 07:23 PM
Z97LT1
N2O Tech
May 25, 2003 11:52 AM
