4#'s vacuum after H/C swap
#31
I would be absolutely sure the valves are adjusted properly and then check for vacum leaks. Take a propane torch like a plumber uses and turn it on so there is a little bit of gas flowing from it. With the engine running...put it near the intake to head seals and around any vacum hoses. If there is a leak..the rpm's will go up to a noticeable extent.
#32
Other areas to check are where the injectors enter the intake manifold. Years ago I found a vacuum leak at one of the injector "O" rings where the #1 injector entered the intake.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!! Graduation Day Parade 20 May 2010!!!
Jake
#33
Jake
Jake
#34
I think in a week-and-a-half it might have been a good idea to actually measure the vacuum, rather than go by what appeared to be a questionable piece of information. Vacuum gauges are cheap.
#35
They shouldn't have been that hard to put in. Did you use any kind of lubrication on the O-rings? If you had to force them in that hard I would think you would roll an oring. Use the unlit torch and look there.
#36
There are several different ways to find a vacuum leak and I've tried most of them over the years. I've been using just plain old water, from my garden hose lately. I'm just careful not to flood the electrical connections or the Opti.
I found the "O" ring leak by flooding the #1 injector area, where the injector enters the intake manifold, with water. The idling engine stumbled and white smoke exited the mufflers.
When I pulled the injector, I found TWO "O" rings on that injector. Apparently when I changed injectors, I didn't notice that one of the "O" rings remained in the manifold. So when I installed the new injectors, the #1 injector ended up with TWO "O" RINGS. That was enough to cause a vacuum leak.
These engines are VERY sensitive to vacuum leaks. Even a very tiny header leak up-stream of the 02 sensor caused my engine to run rough.
Checking for a vacuum leak is GOOD advice. Even if you don't have one, checking will eliminate it as a possible cause.
Jake
#37
From something I read, the "O" rings come in different sizes. So if you used ones that are too large, a leak there is something to consider and check-out.
Jake
Jake
thanks again people! when I finally get some time to look at it I'll let y'all know how I made out, til then if you got any other ideas post em up! =)
gonzo275rltw
3rd Gen / L98 Engine Tech
09-07-2015 04:46 PM
gonzo275rltw
09-05-2015 06:26 PM
gonzo275rltw
09-05-2015 06:24 PM
350350
14
08-11-2015 12:03 PM
