396 NA Plug Recommendations
Old Jul 30, 2004 | 02:29 PM
Matt IFBA's Avatar
I'm needing to get plugs for my new 396. It will be NA, running at 11:1 compression. Would I be ok with the 555s, or is there a different plug that someone would recommend?
Matt
Old Jul 30, 2004 | 02:39 PM
Re: 396 NA Plug Recommendations
The rule-of-thumb is to drop one heat range colder for each 70HP added. Running N/A, I run an AutoLite 103 (2 steps colder than stock) with a 500HP 381 (10.8:1 CR).
Old Jul 30, 2004 | 03:10 PM
Mindgame's Avatar
Good rule of thumb.
Don't just stick em in there and forget it either. Only takes a second to pull a plug and see how things are going. Then you go from there.......
-Mindgame
TitoPR221
May 26, 2015 12:20 AM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
transam_388
Mar 15, 2015 11:53 AM
pimpss96
Feb 12, 2015 01:28 PM
