396 Dynoed @ 467RWHP need Z06 MAF???
Re: 396 Dynoed @ 467RWHP need Z06 MAF???
I just got the Z06 MAF on and to the dyno last weekend. I guess there was a need for more air, because I made 28 rwhp and 33 rwtq more with this setup and a my PCM reprogramed. Thanks for all the input.
Nick
First, I got everything I needed to install the MAF from Kevin at ramchargers.com and I got the actual MAF off ebay. Second, yes my car does run to 7500 rpms+ and no the heads are not to big for a 396 with a solid roller cam and properly setup. Also, the facrory PCM will work just fine to 7500 rpm if properly programmed. We spent two full days on the dyno and the increase hp was from the MAF and dyno tuning (adjust valve lash, knock retard, ect.)... however, the engine had just been tuned on the dyno 3 weeks before by MTI. This time I had a friend that knows his **** help me tune the car.
Originally Posted by fmsracing
I was hoping that someone could answer my orginal question... whether a Z06 MAF is a plug-n-play system with the ramcharger.com adapter and the PCM reprograming?
so you will need a adap. i got mine from the guys at www.zzperformance.com i called them and they sold me one there not listed on there web site but there number is
and yes tunning will be needed for the new maf
David
Shoot me an e-mail and I will send the table, I have someone else who e-mailed me for them, but I got wrapped up in another situation last nite and couldn't e-mail them.
Originally Posted by Z284thgen
no the true Z06 maf is not the z06 maf is a 5 wire and the stocker is a 3 wire
Dave
Yours are the tables that most recently did not work for me.
EW tested the ZO6 MAFs right after they came out and found the calibration to be a mess varying as much as 10% between the few he bought to test, at leas that is what was reported to the b-body forum at the time. Bryan and Ion have both spoken up about it being a PITA. To me that is the big three tuners all giving it the thumbs down. Now if going to a full custom in person tune then a tuner can tune for a screwy MAF, but for email stuff and even just a quick dyno tune you want to use something with known good calibration.
*Shrugs* I have no idea why, I've been running that table for 3 years with 128+/-3 BLMs...
If the factory GM unit is +/- 10% then I wonder what the factory LT1 units are?
tdigger9899
Sep 7, 2015 10:56 AM
