383 with stock heads??
Old Apr 21, 2005 | 05:49 AM
wlz28's Avatar
I've read a few different oppinions on wether or not factory castings will flow enough to feed a 383. I'm doin a rebuild and it will have max port heads but will that be enough? Or would I be better off just goin 355?
Old Apr 21, 2005 | 05:59 AM
rskrause's Avatar
Moderator
Re: 383 with stock heads??
Depends on what you plan to build. if it's a high rpm (7,000rpm+) screamer then stick with the stock stroke. for anything else, go for the cubes.
Rich
Old Apr 21, 2005 | 08:29 AM
wlz28's Avatar
I would like to at least pull 62 -6300 rpm.
Old Apr 21, 2005 | 08:32 AM
rskrause's Avatar
Moderator
High rpm in this context is approaching and above 7K. 6,200-6, 300 should not be a problem with ported stock castings.
Rich
Old Apr 21, 2005 | 08:37 AM
Mystic97Z's Avatar
Rich
u wouldn't want more cubes if you rev higher? doing a 355 and plan on shifting around 6700-6900. just make sure i understood what u meant.
Old Apr 21, 2005 | 09:05 AM
rskrause's Avatar
Moderator
OEM castings will have a tough time flowing enough to support big cubes/high rpm. A 383 at 7,000rpm needs too much air. It would require thousands of dollars of port work if you start with stock castings. Closer to 6,000rpm though and you can have a nice combo with lots of low end torque that pulls strong up to 6,200-6,300.
Rich
Old Apr 21, 2005 | 09:43 AM
WS Sick's Avatar
I agree with you stay on the low side of 6500 rpm the stock castings with biggervalves and nice porting. My AFR 190s just cleaned up make power past 6500, I was kinda surprised. I plan on having them worked over good this coming winter so I'm anxious to see how they do.
Old Apr 21, 2005 | 11:13 AM
wlz28's Avatar
My 306 cam will still work fine in a 383 shifting around 6200 right? or will it try to make power to high up in the rpm range?
Old Apr 21, 2005 | 11:19 AM
WS Sick's Avatar
You'll be fine with the 306, but it will want to shift probably just below 6500.
I have the GM 847 in my 383 , 10.3:1 compression and it will rev to 7000 with ease, but the power starts to drop shortly after 6500
Old Apr 21, 2005 | 11:28 AM
rskrause's Avatar
Moderator
Agree. The drop off is what you would expect. The heads (and intake) are the limiting factor.
Rich
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
markaubuchon
3rd Gen / L98 Engine Tech
Jan 14, 2015 01:48 AM
Killer94z
Jan 13, 2015 12:06 PM
Brian-94TA
Jul 31, 2002 02:52 PM
