383 with stock heads??
I've read a few different oppinions on wether or not factory castings will flow enough to feed a 383. I'm doin a rebuild and it will have max port heads but will that be enough? Or would I be better off just goin 355?
Re: 383 with stock heads??
Originally Posted by rskrause
Depends on what you plan to build. if it's a high rpm (7,000rpm+) screamer then stick with the stock stroke. for anything else, go for the cubes.
Rich
Rich
u wouldn't want more cubes if you rev higher? doing a 355 and plan on shifting around 6700-6900. just make sure i understood what u meant.
OEM castings will have a tough time flowing enough to support big cubes/high rpm. A 383 at 7,000rpm needs too much air. It would require thousands of dollars of port work if you start with stock castings. Closer to 6,000rpm though and you can have a nice combo with lots of low end torque that pulls strong up to 6,200-6,300.
Rich
Rich
I agree with you stay on the low side of 6500 rpm the stock castings with biggervalves and nice porting. My AFR 190s just cleaned up make power past 6500, I was kinda surprised. I plan on having them worked over good this coming winter so I'm anxious to see how they do.
You'll be fine with the 306, but it will want to shift probably just below 6500.
I have the GM 847 in my 383 , 10.3:1 compression and it will rev to 7000 with ease, but the power starts to drop shortly after 6500
Rich
