Ticking
Ticking
ever since I installed my hot cam and roller rockers by engine has had a ticking. I've set valve lash on many solid roller rockers before, so I'm pretty sure I know what I'm doing. If I remember right I want 3/4 past zero lash(stock lifters), I was actually worried about it being to tight.
It's not a loud clatter like valve lash sometimes is, and I've been told that roller rockers always tick a little, no matter how well lash is set.
Is that true?
Is that true?
Re: Ticking
BTW, this IS assuming theyre not loose, but since you said you knew what you were doing, i figure thats a given
anyway
I dont have the car anymore, but after driving 15 k miles or so, one came loose, readjusted it, and 15 K later it came loose again, the rest were fine.
The ticking was VERY noticeable when loose. Otherwise, mine went about 30K miles without needing adjusting (save for that one), then i sold her
anyway, hth
anyway
anyway, hth
importkiller94
Jan 17, 2015 09:03 PM
sc93
Apr 4, 2003 02:47 PM
