383 oil pan
Old Jan 27, 2010 | 09:21 AM
xxteenobesexx's Avatar
383 oil pan
getting a 383 short block w/ my tax return. will i have clearance issues w/ my oil pan. I read that some journals may slightly hit.
I have a 93 Form A4.
Old Jan 27, 2010 | 12:32 PM
Probably depends on the crank brand/model. I have a Callies Stealth crank, and it took a couple very tiny taps with a hammer to eliminate any contact. You can't see the dimples from the outside.
Old Jan 27, 2010 | 07:15 PM
texas97z's Avatar
The scat's crank I have used a few times, had to do the same as what Injuneer is desribing. Too much and you could get K-member interferance if using stock k-member so don't go crazy on it.
Old Feb 22, 2010 | 07:32 PM
thanks alot guys!
Old Feb 25, 2010 | 04:51 PM
Sporty-X's Avatar
mine was not working at all. I got an aftermarket pan with better clearance but still had to hammer it a little on the front.
I have an eagle forged crank
Old Feb 26, 2010 | 01:25 PM
DAVE00's Avatar
That's weird as I have the Eagle forged crank and Ibeams in mine and the stock pan would have fit with some small dimples/taps. However, my builder really wanted me to have a deeper pan and we went with the canton w/built in windage/crank scraper. To the OP make sure that if you go with a HV pump that you DO NOT use the stock pan as you will suc that puppy dry and have pressure dropping issues. Do a search and you'll find ton's of stuff on there and ls1tech.
Old Feb 26, 2010 | 03:04 PM
bombebomb's Avatar
I have a callies compstar crank and if there was clearance on the pan, it was very little (as I never seen any).
As stated above, running stock pan with HV pump is a big gample and the odds are not on your side.
Old Feb 26, 2010 | 06:19 PM
rskrause's Avatar
Moderator
When I had a stock pan the Callies crank did not interfere.
Rich
HectorM52
Jul 30, 2017 11:46 AM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Elcojoe
Nov 17, 2014 10:27 PM
