383 oil pan
Old Aug 20, 2004 | 08:31 AM
lillbush5555's Avatar
383 oil pan
I know this question has been asked a number of times But what oil Pan do I need for a 383. I tried doing a search but only found people saying cantons. I have a 400 Nodler Iron crank with stock shot pined rods and .30 Forged pistions and a meiling MSS High volume oil pump. Canton is to expensive for me so I was wondering is Moroso or Milodon has 1. I have hooker longtubes so I need them to fit around that as well. I had to motor in once and started it to find a LOUD screetching sound. So I had to pull it all out to see the windage tray hadnt been clearnced nor the oil pan. If someone could tell me who makes 1 and pos a part #
Matt
Old Aug 20, 2004 | 08:42 AM
got_hp?'s Avatar
Re: 383 oil pan
i need the same info, but this will get moved out of advanced tech.
Old Aug 20, 2004 | 09:47 AM
kmook's Avatar
Advanced Tech Moderator
Re: 383 oil pan
I had a stock LT1 pan on the 383 I use to have.
And yes this should be discussed in LT1 Engine Tech, transfering.
Old Aug 20, 2004 | 10:16 AM
rskrause's Avatar
Moderator
Re: 383 oil pan
You may be able to clearance the stock pan. I use a stock pan with my 383.
Rich
Old Aug 20, 2004 | 10:21 AM
speedmiser's Avatar
Re: 383 oil pan
Stock pan on my 383 too...
Old Aug 20, 2004 | 08:07 PM
mrz28 73/97's Avatar
Re: 383 oil pan
If you have long tubes I would think that a Moroso or Milodon 86 - up one piece rear seal kickout style pan shold fit our cars but I can't say for sure so maybe someone who has done it will chime in.
HectorM52
Jul 30, 2017 11:46 AM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Elcojoe
Nov 17, 2014 10:27 PM
