383 Le2 Wanting More Power What Can I Do?
Old Oct 26, 2006 | 12:59 PM
  #16
playa7970's Avatar
im running the le3 cam and the exhaust consist of pacesetter LT the cat is eliminated and i have a magnaflow muffler on it
Old Oct 26, 2006 | 01:25 PM
  #17
Sweetred95ta's Avatar
Originally Posted by playa7970
well heres my old post with the graph its pretty blurry though and the reasonit looks the way it does is i believe that the tuner didnt use the smoothing factor but A/F was 13.1 heres the link.. hows it going benji http://web.camaross.com/forums/showthread.php?t=475481
I remember that post. I wouldn't 'add' anything trying to make more power. You should be making more power already. No sense in masking the problem further. You could benefit from richening it up a tad (but not enough to totally make up the missing hp). Did you ever get the knock retard taken care of? Do you happen to have the tune? If you email it to me, I'll take a look at it. If you haven't taken care of the knock retard, I can retard the timing a little in those areas. Send me the log and the program. You should probably take the car to the track and see how it does. I've seen some pretty goofy dyno numbers from cars that were damn quick at the track (and on the street).
Old Oct 26, 2006 | 02:04 PM
  #18
playa7970's Avatar
thanks for help benji im at work now as for the tune file can i save it on tuner cat and email it to if so how? also still havent fixed the KR as of yet and the track i havent been there since january and that was with my stock setup let me know if its possible to do it in tuner cat so i can send it to u thanks bro
Old Oct 26, 2006 | 02:27 PM
  #19
With TunerCAT, just go to one of the drop down menus (I think it's 'Options', but I don't remember) at the top and hit 'Read PCM'. Make sure the key is in the ON position (it will prompt you for this) and hit OK. It's also a good idea to put a battery charger on the battery (I do when I can) and pull the fan relays so that you don't get any voltage spikes. Then, once it's in the laptop, hit 'save as' and save it on your desktop or where ever. Then, go to the same drop down menu and hit 'Program PCM'. It will prompt you again and it will start loading the tune back in. Finally, email it to me with a copy of the log. It's pretty easy.
Old Oct 26, 2006 | 02:39 PM
  #20
playa7970's Avatar
k im home now how long should the data log be?
Old Oct 26, 2006 | 02:55 PM
  #21
Shon Herron's Avatar
WOW, just WOW.
Could it be the short block-Golen right?
Old Oct 26, 2006 | 02:58 PM
  #22
WS Sick's Avatar
If youre seeing knock, that can suck a whole lot of power!
For tuning purposes go into your kncok tables ,zero out the lower ranges and see if the knock sensor sees any actual knock (it will still read the knock , it just won't adjust the timing down for it) Also listen really hard for it as well.
Discontinue this if you hear any sparkknock.
Edit, Forgot to tell you to make sure youre octane is good when searching for that false knock.
Old Oct 26, 2006 | 03:12 PM
  #23
playa7970's Avatar
so when i hit read pcm in tuner cat it actually pulls the program out of my car until i load it back in?
Old Oct 26, 2006 | 03:19 PM
  #24
It reads it. your car will still run like it did before.
now you take that file and make changes to it and program the PCM, those changes will now be in the PCM.
Old Oct 26, 2006 | 03:28 PM
  #25
AdioSS's Avatar
West South Central Moderator
don't fear the gear
put 4.10s in and a good converter
Old Oct 26, 2006 | 03:29 PM
  #26
playa7970's Avatar
cool i just saved the file now and its on my desktop exactly what table should i go into to change the knock retard tables i see about five of them thanks for the help guys
Old Oct 26, 2006 | 03:33 PM
  #27
Originally Posted by AdioSS
don't fear the gear
4.33s or 4.56 if you are man enough
Old Oct 26, 2006 | 09:44 PM
  #28
playa7970's Avatar
heres a data log maybe someone can chime in give me some input thanks
http://www.yourfilehost.com/media.ph...e=camaro11.csv
Old Oct 26, 2006 | 10:52 PM
  #29
97CreamSickL's Avatar
Hey playa,where in Naples are you?
Old Oct 26, 2006 | 11:00 PM
  #30
playa7970's Avatar
im located by pineridge airport you?
