383 compression ratio
Old Oct 28, 2006 | 03:11 PM
kline454's Avatar
383 54cc heads -16 dish pistions compression ratio?
Old Oct 28, 2006 | 03:26 PM
NVetro's Avatar
similar to mysetup. Depending on your head gasket thickness, I was 10.9ish:1 Use a compression ration calculator, search google.
Old Oct 28, 2006 | 04:32 PM
kline454's Avatar
ok thanks
Old Oct 28, 2006 | 04:39 PM
You don't even need to "search google"..... the CR calculator is right here on CamaroZ28.com, along with lots of other helpful calculators. There's a post "stickied" at the top of the forum topic listing with the link to the calculations page.
https://www.camaroz28.com/calcs/cr.html
Old Oct 28, 2006 | 05:06 PM
NVetro's Avatar
That one works also
Old Nov 4, 2006 | 05:57 AM
BlueCamaroZ28's Avatar
I have the same setup. Was told by Bret that I should've got flat top pistons and should not have used -16cc dished pistons cause compression will be low, although my calculation shows 10.8:1 SCR.
I am thinking to switch to flat top pistons. Surprized to see some are using -16cc dished pistons as I did with 383.
Old Nov 4, 2006 | 10:33 AM
SS MPSTR's Avatar
yep...and what a mistake it was.
Old Nov 4, 2006 | 10:59 AM
But check what it says, 11.8 CR with 58 cc. With 54cc, it will be above 12:1 CR which is high for pump gas.
http://www.cnc-motorsports.com/produ...092&CtgID=9038
This is why I went with -16cc pistons and still think it was a right choice with DD camshaft like cc306, I was using at first.
Do you think flat top pistons, 54cc head and cc306 at 12+:1 CR will work with pump gas? Tell me I was wrong.
Old Nov 4, 2006 | 11:59 AM
SS MPSTR's Avatar
Solve for DCR...if DCR is less than ~8.5, it will run fine on pump gas.
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
surreybrad
Sep 29, 2015 09:00 PM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
