355ci /putting Out 460hp
Old Sep 2, 2004 | 09:46 PM
IRONCROSS97's Avatar
Question 355ci /putting Out 460hp
i have a slight problem at the high end i need more fuel the dyno guy says shes runnin to lean and i need to reprogram my rev limiter, it kicks in b4 my hp curve goes down. who makes a good adjustable fuel reg for the lt1 ?
http://www.cardomain.com/id/ironcross97
check out the look. she is a real head turner with looks and her cam pops away at the red lights at a idle. the best of all is she looks totally stock under the hood.
Old Sep 2, 2004 | 09:52 PM
xxsaint69x's Avatar
Re: 355ci /putting Out 460hp
you made 460 rwhp?
or the motor made 460 hp?
Dyno sheet?
Old Sep 2, 2004 | 10:14 PM
the car made 375.52 rwhp my problem is she is runnin to lean at the high end and my rev limit kicks in b4 the curve goes down. im looking for a good adjustable fuel reg for the lt1 any sugg.
Old Sep 2, 2004 | 11:13 PM
Spinner's Avatar
fuel reg wont help you. get a better pump and bigger injectors
Old Sep 3, 2004 | 05:49 AM
Fastbird93's Avatar
Some info on your setup would be very handy to help. Basically what spinner said though. A fuel pressure regulator won't help you since the computer is just going to compensate for it anyway. Pick yourself up a set of SVO 30# injectors and go from there.
Eric@Victory Racing
16
Oct 31, 2006 06:16 AM
Acct 23749
Oct 3, 2006 09:11 PM
carbed93Z
Dec 3, 2004 10:57 AM
