seafoamed yesterday now car runs like crap at idle please help!!
Old Sep 1, 2004 | 07:40 PM
red96z's Avatar
used seafoam yesterday got a lot of smoke like usual and now car wont idle right jumps up and down and dies alot but once i get going its not doing it took off the throtle body and cleaned the iac and tps and still does it also threw ses code p0100,p0101,and maybe cant remember p0102,along with the missfire code p0300.not sure what it is need to figure out fast cause if i cant i will have to put in shop fri any help will do thanks in advance.randy
Old Sep 1, 2004 | 07:48 PM
LT1Squirrel's Avatar
Re: seafoamed yesterday now car runs like crap at idle please help!!
you take out your O2's?
Old Sep 1, 2004 | 07:52 PM
slopokrodrigez's Avatar
Not to mention the cats are clogged to beat the band now.
Old Sep 1, 2004 | 09:26 PM
Can't see how MAF codes are related, unless you poured the Seafoam in front of it.
Old Sep 1, 2004 | 09:41 PM
Or forgot to plug the MAF back in.....
Old Sep 1, 2004 | 10:21 PM
red96z's Avatar
i did not remove the 02s and i have no cats nor did mess with the maf sensor i poured the seafoam in the middle outlet on pass side of the tb like i have done before that would not have messed up the 02s enough to cause that sort of problem would it? i mean when i get going its fine its just like its fighting to stay alive at low rpms.what gives??
Old Sep 1, 2004 | 10:22 PM
seafoam gave the final blow to my O2's
Old Sep 1, 2004 | 10:28 PM
red96z's Avatar
they are new delcos with maybe 10,000 miles on them.
Old Sep 1, 2004 | 10:40 PM
Spinner's Avatar
Seafoam will foul your plugs and O2s. Change them, and it'll go away
Old Sep 1, 2004 | 11:34 PM
Mir Hussain's Avatar
Arrow Re: seafoamed yesterday now car runs like crap at idle please help!!
Originally Posted by red96z
code p0100,p0101,
Are MAF erros
p0300.
is a misfire!
Old Sep 2, 2004 | 07:12 PM
red96z's Avatar
correct me if im wrong but when ur car is cold it does not use the 02s until it gets warm cause this morning after sitting all nite long could not keep it cranked everytime i put it in gear it would die wouldnt idle right or nothing couldnt even keep it running by giving it gas.btw plugs are new too
Old Sep 3, 2004 | 07:06 AM
Dave Holland's Avatar
Did you do this on a warm or cold engine? If you get the engine up to operating temp before using the SeaFoam, you shouldn't have problems with the o2's or plugs fouling.
-Dave
Old Sep 3, 2004 | 07:46 AM
rocmemphis's Avatar
Go and drive the car fairly hard for a little while. Every time I seafoam my car I will get KR which makes the car run bad. If that doesnt fix it then do whatever one else says and change the plugs and O2s.
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
ro2207
Dec 4, 2014 06:18 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Brent94Z
Mar 21, 2002 04:44 PM
