355 LT1 woes
Old Apr 6, 2007 | 08:33 PM
  #31
seawolf06's Avatar
No, there is a blue and a black. The connector only works one way. Some have had them wired backwards, though. That's what I'm trying to make sure mine isn't.
Old Apr 7, 2007 | 12:22 PM
  #32
JP95ZM6's Avatar
Crank does spin clockwise (I went and looked at my 5.3l Tahoe to be sure), and there are only the 2 gears involved, one on the cam sprocket and one on the pump. So as I wrote earlier, the stock mechanical impeller spins opposite the crank, ie CCW as viewed from the front. So, I think the question is now narrowed down to wether the Meziere is intended to go the other way.
Old Apr 7, 2007 | 12:38 PM
  #33
seawolf06's Avatar
Guess I'll have to wait until monday to call and ask them. I hope this is the answer, that would be so easy and more importantly, FREE to fix. haha.
The next thing I can think could possibly be wrong is radiator cap. OR for some reason if my heater core bypass has something to do with it.
Old Apr 9, 2007 | 10:06 PM
  #34
seawolf06's Avatar
Ok, Called Meziere and they said that it is running correctly. It is turning CW looking at the front of the motor which is the same way that the stock pump turned. So it's not that.
One of the older guys at the shop said it could be that the coolant is moving too fast through the lines and suggested I closed off the steam pipe line from the heads to the radiator. I tried that and it didn't work either.
Should I get the radiator and cap pressure tested?
Old Apr 9, 2007 | 10:42 PM
  #35
mdacton's Avatar
did you ever put a t-stat back in it?
Old Apr 10, 2007 | 11:50 AM
  #36
seawolf06's Avatar
Yep, 160 degrees.
DirtyDaveW
Mar 15, 2015 07:01 PM
Nostang 96z
Sep 15, 2002 10:15 PM
Nostang 96z
Sep 14, 2002 08:22 PM
Nostang 96z
Sep 10, 2002 08:54 PM
