Loss of Power
Old Apr 4, 2007 | 10:44 AM
LTgun_94's Avatar
Loss of Power
Well just recently i got my 94 z28 running again after several months of downtime due to a crappy MSD opti. So its back running now and it seems like it has lost some of its power. A couple of questions:
1) How much is a low coolant light hurting me?
2) I switched the PCMs while in the process of eliminating things that was wrong with the car...is it possible the other PCM had a tune and now i got a stock tune?
Answers/suggestions are appreciated!!!
Old Apr 4, 2007 | 11:11 AM
2000GTP's Avatar
Is the coolant level low? If so, I would address that issue although I don't think it would be solely responsible for the power loss. Its possible your other PCM was tuned, but you wouldn't know unless you swapped them around again or had a tuner hook it up and look at it. I would check over some simple things to, pull the plugs and make sure they are in good shape. If you have stock Delco plats, it is pretty common for the pucks to fall off creating a very large gap which can really degrade performance. It wouldn't hurt to check the wires also and put a fuel pressure gauge on it.
Old Apr 4, 2007 | 11:21 AM
LTgun_94's Avatar
Well plugs are NGK TR-55 GPs which are pretty new, has a new fuel pump with a pressure of around 42-43 at idle. But im positive the coolant level is right, the water level is right in the overflow tank...the thing is sometimes the light comes on and other times it doesnt, could the sensor be bad???
Old Apr 4, 2007 | 11:23 AM
2000GTP's Avatar
The sensor can get gummed up or the connection could be loose or dirty triggering a false dash light.
Old Apr 4, 2007 | 11:37 AM
LTgun_94's Avatar
Will that hurt performance any tho?
Old Apr 4, 2007 | 01:56 PM
2000GTP's Avatar
No, that input is independent of the PCM and only goes straight to the dash.
Old Apr 4, 2007 | 02:18 PM
oneclean97z's Avatar
mine does the same thing, the low radiator or whatever light will randomly come on and off along with the ses light, they dont come on/ off at the same time most of the time though. where is the low coolant level sensor cause i will take a look at mine
Old Apr 4, 2007 | 02:20 PM
2000GTP's Avatar
Its in the drivers side head.
Old Apr 4, 2007 | 02:22 PM
nvm i found it on shoebox's site
Old Apr 4, 2007 | 05:06 PM
LTgun_94's Avatar
Well it just puzzles me tho. I guess a tune can make big difference. The power loss seems more up top then in the bottom rpms....its just not what it used to be
Old Apr 10, 2007 | 01:08 PM
nodnarb481's Avatar
im going through the same thing right now... figure anything out yet?
warmeck
May 7, 2015 02:10 PM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
thenewkid
Nov 27, 2014 09:41 AM
XtremeLt1
Sep 13, 2002 08:50 PM
slothgrant
Aug 22, 2002 03:01 PM
