32# injectors on stock motor?
Old Nov 15, 2004 | 05:26 PM
karl81talt1's Avatar
I put racetronix 32# injectors in a stock lt1 with what u could say is a cai and an y-pipe back exhaust. Its in my 81 ta with an m6 and 3.08s. it feels to me that it runs great but i think it has to be running rich. I did use lt1 edit to recalibrate for the injector size. Also would i have to tune out my egr system if i remove thatnks in advance.
Old Nov 15, 2004 | 08:21 PM
SBCGENII's Avatar
Re: 32# injectors on stock motor?
those are way to much injector
Old Nov 15, 2004 | 08:26 PM
DiabloGT's Avatar
does anything bad happen with too much?
Old Nov 16, 2004 | 02:14 PM
There is no problem running that size injector, as long as you have programmed the correct flow rate constant and offsets. You will simply find that the injector duty cycle has dropped off a bit, and that is "good". No harm at all in running an oversize injector, as long as you don't get ridiculous. Of course there won't be any performance gain either.
Old Nov 16, 2004 | 03:07 PM
"White Knight"'s Avatar
I was always curious how big you can go and tune it down, before you start hurting performance?
Old Nov 16, 2004 | 03:25 PM
TobyZ28's Avatar
I posted that exact question yesterday.
http://web.camaross.com/forums/showthread.php?t=317914
Thats what i've figured out so far.
Old Nov 16, 2004 | 03:38 PM
The Cartel's Avatar
exactly. Your runnin a 3.08 rear gear w/a 6 speed? 6th gear has got to be worthless.
Jason
Old Nov 17, 2004 | 03:55 PM
I didnt get a chance to run it with the stock injectors so i cant tell if the performance moved but i doubt it did. I also didnt mess with any offset tables just the injector size in lt1 edit. And 6th gear works ok withthe 308s but will be alot better with the 390s i plan to install as soon as i base line the car at the track. hell it still has thee camaro manifolds and y pipe on it. ANY INFO ABOUT TUNING OUT THE EGR AND AIR PUMP WOULD BE VERY USEFUL SO I CAN PUT MY HEADERS ON IT. BY the way will gen 1 headrers fit the lt1 heads. I know the dont fit on the 4th gens body but i think they should fit.
Old Nov 17, 2004 | 04:23 PM
crash4cyl's Avatar
If you get headers for the d-port exhaut and the 23 degree that the heads are you shoudn't have a problem but I don't know if the generic headers that fit your car will bolt up to the LT1. You may have to basically splice the LT1 flange onto a set of Super Comps...you may be able to have hooker do it for you.
Good Luck
Chris
HectorM52
Jul 30, 2017 11:46 AM
Cam's maro
Jan 30, 2015 09:21 PM
blac94Z
Jan 22, 2015 11:19 PM
spearous
Jan 12, 2015 11:03 AM
