Is 30ft/lbs on cam bolts "okay"?
Old Nov 30, 2004 | 03:01 AM
BlackLT1_TX's Avatar
I didnt know the spec, and was in a hurry, and just put a small dab of thread lock and 30ft/lbs on the cam bolts, you think that it will be okay?
Would too much torque put unwanted stress against the thrust plate?
Thanks,
james
Old Nov 30, 2004 | 07:48 AM
izzyz28's Avatar
Re: Is 30ft/lbs on cam bolts "okay"?
They'll be just fine. I think the recommended torque is 18 ft-lbs. or something rediculously low like that. I usually torque mine to around 25 with a dab of blue loctite in case I want to remove them later.
96z
Sep 8, 2002 07:34 AM
96z
Sep 5, 2002 07:53 PM
96z
Aug 22, 2002 04:05 PM
96z
Aug 17, 2002 09:29 PM
96z
Aug 9, 2002 03:51 PM
