3:73 gears what else do i need
Old Jul 11, 2003 | 05:08 PM
ericz28w's Avatar
just got some 3:73's that are fairly new (just the gears), and i was wondering what else im gunna need to install them,
fluids? or anything else?
Old Jul 11, 2003 | 05:20 PM
BlkZ28M6's Avatar
Get sythetic gear lube i recommend Amsoil. Also you are going to need a new crush sleeve and shims. I recommend all new bearings and axle seals and pinion seal. You will need a new gasket and marking compund to check the patttern on the gear. I would try the install unless you really know what your doing. Its not hard its just you need to make sure everything is right ex. backlash, pinion depth. Certain things you are going to need special tools for. Good Luck!
blkWidow
Apr 21, 2015 01:56 PM
REDNECKISBOSS
Apr 17, 2015 07:14 AM
CARiD
Apr 8, 2015 08:08 AM
Dr. Weir
Aug 2, 2002 02:36 AM
