Name that noise
Old Jul 11, 2003 | 03:49 PM
americanmusscle's Avatar
Talking Name that noise
Its frigging hot here in arizona so when i turn my a/c on there is a weird ticking noise that comes on with it. It sounds like it is the heater core but after a while I turn the A/C off and on again and it is gone?? Its annoying and its nothing in the golve box rattling around. Anyone have any ideas??
Old Jul 11, 2003 | 03:54 PM
DelSoto's Avatar
Does the noise change pitch or rate of clicking as you change fan speeds. Might be in the blower motor. Just a guess.
Old Jul 11, 2003 | 03:56 PM
Gets faster as the speed increases. So when at low it is low ticking and when the a/c **** is turned its increases in ticks
Old Jul 11, 2003 | 03:57 PM
DelSoto's Avatar
blower motor then...or the squirrelcage fan came loose or someting got int there.
Old Jul 11, 2003 | 04:03 PM
TransAm219's Avatar
It is probably just your condenser kicking in
Old Jul 11, 2003 | 04:42 PM
DelSoto's Avatar
Don't you mean compressor? I thought that too but if the noise changes as you change fan speeds, it is definitely the motor or something in there. Try running just the fan w/o the ac on and see if it still makes the noise. If it does, you'll know it's something to do with the blower motor.
Old Jul 11, 2003 | 04:59 PM
Anyone know how much a blower motor would run?
Old Jul 11, 2003 | 05:14 PM
DelSoto's Avatar
AC DELCO 15-8760 $121.78 @ carparts.com. I bet you can find it cheaper if you do a little searching tho. I wouldn't run out and buy one just yet. Pull the old one out and see if something came loose in there.
Old Jul 11, 2003 | 05:20 PM
Thanks guys for your help
autoxr166
Sep 25, 2015 04:21 PM
rideordie
Sep 7, 2015 08:22 AM
colts0455
13
Aug 7, 2015 09:15 PM
GT what?
Jul 14, 2015 10:17 PM
colts0455
Jul 7, 2015 07:19 PM
