2bolt 4 bolt which do I need
Old Apr 12, 2008 | 03:06 PM
bombebomb's Avatar
I read some other posts and got good information, but non exactly like my question.
Im building a 383, all forged internals compstar, je pistons, heads down the road, cam going in it now.
Im also planning on running a 300 shot. Couple people have told me to just stud the 2 bolts because they will do just fine, but I think id be stupid not to 4 bolt a 600+whp motor. Your opinions?
Old Apr 12, 2008 | 03:10 PM
If you plan to run a 300-shot, you would be foolish not to run 4-bolt mains.
Old Apr 12, 2008 | 03:11 PM
bombebomb's Avatar
Thank you, I was thinking the exact same thing, just wanted to "check" on it from the 20k experts
Old Apr 12, 2008 | 03:12 PM
cvccbum's Avatar
not to high-jack but I have the same question myself. I'm going to be running a 355 running 15~ pounds of boost with a T76. Just stud the 2 bolt or splay to 4?
Old Apr 12, 2008 | 03:13 PM
bombebomb's Avatar
If you have the money id splay it without question. Im no FI expert though.
Old Apr 12, 2008 | 03:18 PM
96capricemgr's Avatar
Fred will make his argument for straight 4-bolt mains but I just think it important to use quality main caps and fasteners and either splayed or straight will work.
By the time you pay for putting new maincaps on a factory 4-bolt block probably wont save you anything because of the premium you will pay for it in the first place.
How fast are you planning to run?? I would expect with any decent heads a 300 shot should be well into the 9s at the slowest. I understand that from the other post you won't be running worked heads for the time being just wonder if your 300 shot goal is a reasonable one.
Old Apr 12, 2008 | 03:21 PM
bombebomb's Avatar
300 will not be going on yet, ill do the heads before I go 300 shot, I may start with smaller shots, but in the end 300 will be it.
Iv read freds argument in another 2bolt vs 4bolt thread.
Theres no dout with a stock cast head a 300 shot is "unreasonable". I just want to make sure the bottom end will take it, I can do all the top end down the road without pulling the motor.
As far as "how fast" I want to run, basicly where ever it takes me, however I want to be able to still drive it for example all interior is staying in it etc.
Victor Lamb
Aug 26, 2017 02:52 PM
BLK1997Z28
May 2, 2015 01:26 PM
maybe2fast
Mar 16, 2015 09:45 AM
ddr698
Jan 9, 2015 10:05 AM
