267,000 miles and finally let go...some pics inside!
Old Jun 21, 2006 | 08:15 PM
  #46
95 Z/28 LT1's Avatar
Super Moderator
Re: 267,000 miles and finally let go...some pics inside!
Let's keep this one around for a while.
Old Jun 21, 2006 | 08:19 PM
  #47
speed_demon24's Avatar
What kind of oil did you use in it, that way we know what not to use because of the buildup it has.
Old Jun 21, 2006 | 09:12 PM
  #48
TobyZ28's Avatar
Bent Rod because of hydrolock due to a leaky head gasket? I've heard of that happening before, it's quite common as far as catastrophic engine failures go.
At least you didn't have a cylinder wall in the block crack (like me) completly out of the blue.... Nobody knows why it happend.. was religious with oil changes too.
Old Jun 21, 2006 | 09:55 PM
  #49
Hark_z's Avatar
Why is this a sticky now? LOL! It's historic.
Old Jun 21, 2006 | 10:06 PM
  #50
JasonD's Avatar
Admin Emeritus
Damn right! When was thet last time you saw mileage like that?
Old Jun 22, 2006 | 04:05 PM
  #51
marshall93z's Avatar
I attribute that to the numerous times the motor has reached 300 degrees! Probably 12-15 times. Kinda baked it, I guess?
Havoline 20W-50
Old Jun 23, 2006 | 01:20 AM
  #52
MachinistOne's Avatar
I've got 187,000 on my opti - still going.....My engine is nice and clean though, so I don't know how well it will hold up without that custom oil weatherproofing you have got on yours
Old Jun 23, 2006 | 01:31 AM
  #53
Wckd94Z's Avatar
Originally Posted by Grease
Are you going to rebuild it or get another stock engine to put in there? You could reuse the opti
ROFL, that made me laugh pretty good. Sad thing is, my 80k mile 94 had more gunk on the front than yours when i tore it down for the cam swap. I HAD leaks at the intake, timing cover, front and rear crankshaft seals, wp seal, and opti seal... pan gasket still sealing up fine
Old Jun 23, 2006 | 06:00 AM
  #54
IllusionalTA's Avatar
Think of it as "heat Treated"
Old Jun 23, 2006 | 02:42 PM
  #55
Damn!
Old Jun 26, 2006 | 07:51 AM
  #56
multicar's Avatar
Curious as to what kind of coolant you were using and what the change interval was on it.
Doug
Old Jun 26, 2006 | 09:49 AM
  #57
96_pimped_out's Avatar
267k... stock opti?
Old Jun 26, 2006 | 01:22 PM
  #58
bad93z's Avatar
Yeah just scrape off the sludge and reuse that opti
Old Jun 26, 2006 | 04:49 PM
  #59
bgmz282's Avatar
i forget how many opti's ive been through... Six i can count of in my 96 z28. 192,000 on the clock and 50k on the motor, 3 opti's on the new motor. Im hell on them
Old Jun 26, 2006 | 04:52 PM
  #60
Correction: They're hell on YOU.
