233/239 vs 236/242
Old Jan 16, 2006 | 11:38 AM
Loadre's Avatar
233/239 vs 236/242
I know these are two cams more on the extreme edge of what people tend to run but I was looking for some feedback. My 224/230 is much too small for me and I'm getting ready to yank it. It's going on a forged 355 with CMS Stage II heads/intake, full boltons, yada yada.
So gimme the pro's and con's of each if you've had one or the other.
Old Jan 16, 2006 | 12:43 PM
'94 Bad A Z28's Avatar
Re: 233/239 vs 236/242
I have a 234/242 and love it.
Old Jan 16, 2006 | 12:47 PM
Loadre's Avatar
How is driveability? What does your cam peak at on what LSA?
Old Jan 16, 2006 | 12:55 PM
The car only has a quick tune for the 36lb injectors right now, the cam is an a 112LSA and the driveability is great. The car is not fully tuned yet so I couldn't tell you peak numbers, but I can tell you that around 4200RPM's in 2nd gear the assend breaks loose and starts to slide out. The car deffinately has plenty of power. The car has a Yank 2800 Converter in it aswell.
Old Jan 16, 2006 | 01:39 PM
disco192's Avatar
I have the 236/242 XE grind cam in my LE2 383. It pulls real strong and is a good cam for a stroker as it is a lower RPM motor. The problem with the XE grinds is that they start to fall off at high RPM, which you will need in a 355.
IF you decide to go with this cam, I would recomend a very light drivetrain and a rev kit to keep the lifter on the cam.
Old Jan 16, 2006 | 06:13 PM
crAzy95z28's Avatar
thats the size of my cam, but the highest lift is 579. Its also going in a forged 355
Old Jan 16, 2006 | 06:20 PM
flyinZ's Avatar
Just ask CMS since they're the ones doin' your heads..
Old Jan 16, 2006 | 06:22 PM
Loadre's Avatar
The heads are already done, plus I like to get responses straight from the people that actually drive the cars with the mentioned cams.
Old Jan 16, 2006 | 08:31 PM
JustNO's Avatar
How often you drive? Daily? Did you take her to dyno?
236/242 will be more radical to drive in 355cid than 383cid.
Old Jan 16, 2006 | 09:53 PM
my94blackz's Avatar
233/239 hands down
Old Jan 17, 2006 | 03:03 PM
madwolf's Avatar
I have the 233/239 and have personally tuned/drove a few cars with the 236/242. Both very nice cams.
Old Jan 17, 2006 | 03:20 PM
SStrokerAce's Avatar
I know what the lobes are on the 233/239 and I'm not a fan of those. The 236/242 no clue what lobes you are running.
Bret
Old Jan 17, 2006 | 07:50 PM
Loadre's Avatar
Bret
Why are you not a fan? Elaborate please.
Old Jan 17, 2006 | 09:53 PM
The lobes are very hard to control the valves with. Thats why I dont use them.
Bret
Elysian
Mar 4, 2004 05:08 PM
GetaZforgetGT
Mar 3, 2004 07:28 PM
1BadBrd
Mar 2, 2004 07:44 PM
madwolf
Nov 22, 2003 10:54 PM
TUFF LT1
Nov 3, 2003 02:19 PM
