230/236 with 1.7's?
230/236 with 1.7's?
i have a 230/236 112lsa installed at the moment, still on stock rockers due to money issues.
anyhow i'm wondering if i should go with the scorpion 1.7's or a pro mag 1.6
has anyone dyno'ed this cam or a similiar cam with 1.7's? does it hurt or help?
also, will there be a problem with the vavle geometry with stock length pushrods.
thanks
mike
thanks
mike
Guest
Posts: n/a
Re: 230/236 with 1.7's?
I have a friend getting ready to do the same thing with his 230/236 XE Comp Cams. He is useing a 3/8" ARP stud, CC pushrods, 918 springs. It is all within the specs of the springs etc, but what about the studs? Are they strong enough for stability? Or should you go to the 7/16" studs for strength, event hough ARP are stronger than factory.
Guest
Posts: n/a
Originally Posted by limige
ps, i'm not interested on what they did with a stock cam or hotcam.
But, you should see a gain, as the Hot Cam with a 350LT1 and the 1.7's made 14rwhp with a 6 speed car, corrected.
Guest
Posts: n/a
cam is a CC XE 230/236 112 .550lift or so with 1.6's.
springs are CC 941's
stock valves
CC hardened pushrods
stock valves
Guest
Posts: n/a
stock valves
stock valves
I have the same cam (230/236 .545"int .555"exh 112LSA w/ 1.6s) and your lift will go up w/ the new rr's. you can calculate this by (.545"/1.6)*1.7 so your new intake lift is .579 and exhaust is .590
You need new springs for that (im pretty sure, I wouldn't use 1.7s w/ my excomponent 612 springs) and I am almost positive the 918 comp springs will work for that, but I would ask comp.
Guest
Posts: n/a
yeah, i was wondering about that, i think the 941's are good to around .575 lift or so. couldn't remember.
http://www.compcams.com/Technical/Cu...ML/329-338.asp
94 CAMRO Z28
Nov 22, 2003 12:19 PM
