It's running... 230/236 Cam.
Old Mar 2, 2003 | 09:47 PM
Ken95Z28's Avatar
Ok, I got a 230/236 Cam on 111LSA with Combination Motorsports Stage II heads.
No times or dyno yet, hopefully I will have the car on the dyno this week and at the track right this Saturday.
Should have some times for all of you..
If you want to listen to it.
230/236 Cam File size is 2.3mb
Old Mar 2, 2003 | 09:51 PM
ltlhomer's Avatar
Badass man! If mine sounds remotely close to that (which is should since it's pretty much identical except mine is 112lsa and yours was 111), I will be the happiest man on the planet. :-)
Old Mar 2, 2003 | 10:18 PM
Mr. T's Z's Avatar
That sounds AWESOME!!!!! That is the same set-up I am putting in. NOW I CAN'T WAIT!!!! Let me know the dyno numbers.
Tyler
Old Mar 2, 2003 | 10:24 PM
97Z-M6's Avatar
well mines going to be on a 108lsa im curious to how yours sounds but ill listen to it tommorow at work when i can use the t1 line. dial up sucks.
which cam did you get the XH, HL,or XL. im going on the XH.
and have you done tunning yet.
Old Mar 2, 2003 | 10:34 PM
br1ev8's Avatar
awe man, you gave up on the hot cam?!?! your car was like the fastest hotcam'd car on this board. I was amazed at how fast you got your car to go on that cam. using the same determination you had with the hc, your car should really hustle now. sweet cam, let us know the results on the innitial run.
Old Mar 2, 2003 | 11:14 PM
hsyr's Avatar
Damn! I can't wait to get a 230/236 in my car. That sounds f*cking badass . Get it on the dyno, im curious to see what #'s your putting down.
Old Mar 2, 2003 | 11:18 PM
allmotorta's Avatar
Sweet! I'm just as anxious as you to see what it does, how does the ole buttometer feel? Can't wait to see how the Combo heads perform
Old Mar 2, 2003 | 11:52 PM
mastrdrver's Avatar
Now I can't wait to get mine in. First I have to get a car, sold the one I had at the time. Only diff is mine is on a 110LSA. I know one other guy on this board that has this cam IN, and he says it sounds awsome. You guys are really making me jealous
Old Mar 3, 2003 | 12:49 AM
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
I've got the same cam in my car... Well, 230/236 "HL" grind. On a 110LS though. Having some issues where I can't rev past 6k right now. Still troubleshooting it and hope to have it figured out soon.
But the cam does show a lot of promise .. Short-shifting @ 5k - vs. 6800 or so <- where it should peak @ w/ my setup... I ran a best of an 8.14@84.5mph in the 1/8 ~ and a bunch of 12.8's @103-104mph.. I had to shift into 5th @ the 1000' mark. My "powerband" w/ my CC306 was from 4k-6.6k. Best ET I managed out of that was a 11.9@115mph. W/ the 230/236 - my powerband was moved way down to 2400rpms - 5k. And still it ran a 12.8. It's gonna run easy 11's I think once I can run it to it's full potential.
running down the track..
Old Mar 3, 2003 | 01:29 AM
NiteRider's Avatar
Good show, we got mine finished up on saturday, sounds just like that, cept it's thru a hooker. Badass sound! All I can say is the cam is great even on stock heads. MMM mmmm mmm!
Old Mar 3, 2003 | 08:32 AM
Ken95Z28's Avatar
That's with the idle setting about 1000-1050 rpm.
The cam is an XL grind.
Took it for a spin last night and really only got on it once, it pulled nicely up to 6,000 that's when I lifted off than. The car pulls very nicely.
You can tell there is some cam surge to it, but with high stall converter it takes some of the cam surge away.
The poly-engine mounts are working great. The keep the motor pretty solid in place.
The car has a 52mm TB with 30# SVO Injectors, of course it has a dual setup exhaust running through some Hooker LT's.
Need to heat cycle it some more to break in the springs and check header bolts.
Old Mar 3, 2003 | 08:46 AM
All_Z_Way's Avatar
Thumbs up
I can't wait to get my installed. It is just sitting in garage right now.
But I have this weekend's track day, then I can start tearing it apart.
Old Mar 3, 2003 | 09:35 AM
LT4POWR's Avatar
Awesome setup!!!
Old Mar 3, 2003 | 10:06 AM
Gripenfelter's Avatar
Sounds alot lumpier than mine. SWEET!!
Mostly cuz my longer stroke swallows alot of my idle.
Vid in sig.
Old Mar 3, 2003 | 10:35 AM
solid95z's Avatar
Sounds great...Keep us posted on those dyno #'s and times. I an fixing to install the same cam with a set of heads for a friend of mine on hhis stock bottom end and he is curious to see how yours does.
Good luck with it Ken.
Scott
sh0ckl3y_z28
Oct 3, 2015 06:34 PM
MDZ28
11
Sep 24, 2015 09:15 AM
S. Holley
Oct 25, 2002 05:27 PM
xxsaint69x
Sep 26, 2002 10:23 AM
ElkyRacer
Advanced Tech
Sep 3, 2002 01:27 PM
