230/236 with 1.7's?
Old Jan 26, 2006 | 09:28 AM
limige's Avatar
230/236 with 1.7's?
i have a 230/236 112lsa installed at the moment, still on stock rockers due to money issues.
anyhow i'm wondering if i should go with the scorpion 1.7's or a pro mag 1.6
has anyone dyno'ed this cam or a similiar cam with 1.7's? does it hurt or help?
also, will there be a problem with the vavle geometry with stock length pushrods.
thanks
mike
Old Jan 26, 2006 | 09:29 AM
limige's Avatar
Re: 230/236 with 1.7's?
ps, i'm not interested on what they did with a stock cam or hotcam.
Old Jan 26, 2006 | 01:58 PM
SStrokerAce's Avatar
What 230/236 cam?
You gotta make sure the springs and the rest of the system work well.... you ever see those LS1 boys collapse lifters and bend pushrods? They have 1.7's too.
Bret
Old Jan 26, 2006 | 04:14 PM
Joebagodonuts
Guest
Posts: n/a
I have a friend getting ready to do the same thing with his 230/236 XE Comp Cams. He is useing a 3/8" ARP stud, CC pushrods, 918 springs. It is all within the specs of the springs etc, but what about the studs? Are they strong enough for stability? Or should you go to the 7/16" studs for strength, event hough ARP are stronger than factory.
Old Jan 26, 2006 | 04:16 PM
Joebagodonuts
Guest
Posts: n/a
Funny how I posted about the HotCam with these.
But, you should see a gain, as the Hot Cam with a 350LT1 and the 1.7's made 14rwhp with a 6 speed car, corrected.
Old Jan 26, 2006 | 07:30 PM
limige's Avatar
cam is a CC XE 230/236 112 .550lift or so with 1.6's.
springs are CC 941's
stock valves
CC hardened pushrods
Old Jan 27, 2006 | 10:42 AM
limige's Avatar
bump, this cam has more lift i'm just wondering if the additional will be any help.
also, has anyone had problem trashing 1.7's due to bad geometry?
Old Jan 27, 2006 | 01:08 PM
Joebagodonuts
Guest
Posts: n/a
stock valves
You might want to change those valve springs. they are very stiff single springs. I went through a few, as they were originally put on my motor by MorePerformance via CNC. They had problems over at Katech motors with them also. I changed over to 918s and have been trouble free. And the 918s can handle more lift, I beleive.
Old Jan 27, 2006 | 01:13 PM
Joebagodonuts
Guest
Posts: n/a
stock valves
Old Jan 27, 2006 | 01:20 PM
96LT1TX's Avatar
I have the same cam (230/236 .545"int .555"exh 112LSA w/ 1.6s) and your lift will go up w/ the new rr's. you can calculate this by (.545"/1.6)*1.7 so your new intake lift is .579 and exhaust is .590
You need new springs for that (im pretty sure, I wouldn't use 1.7s w/ my excomponent 612 springs) and I am almost positive the 918 comp springs will work for that, but I would ask comp.
Old Jan 27, 2006 | 04:14 PM
limige's Avatar
yeah, i was wondering about that, i think the 941's are good to around .575 lift or so. couldn't remember.
Old Jan 27, 2006 | 04:23 PM
Joebagodonuts
Guest
Posts: n/a
About half way down are the specs.
http://www.compcams.com/Technical/Cu...ML/329-338.asp
sh0ckl3y_z28
Oct 3, 2015 06:34 PM
Cam's maro
Aug 11, 2015 07:45 AM
94 CAMRO Z28
Nov 22, 2003 12:19 PM
Ken95Z28
Mar 3, 2003 10:35 AM
Jason Short
Advanced Tech
39
Nov 6, 2002 02:16 PM
