Is 22 PSI of Oil Pressure using the PF1218 Normal it Used to be 25 with the PF25?
Old Aug 17, 2003 | 10:43 AM
LeeS's Avatar
Question Is 22 PSI of Oil Pressure using the PF1218 Normal it Used to be 25 with the PF25?
Hi GUys!
I changed oil yesterday and I couldn't find the PF25 anywhere since the stoped making them. So I used the PF1218 instead of the PF454 that was supposed to replace the PF25.
I had about 24 or 25 PSI with Engine Hot at idle now I am Getting 21-23 at Idle with the Engine Completely warmed up to operating temp at 210F.
Do you guys think this is a problem? I thought the PF454 was just too small.
I use Mobil 1 Fully Synthetic Oil and I have 73, 960 miles on car!
THanks Lee!
Old Aug 17, 2003 | 11:25 AM
LeeS's Avatar
Where is everybody?
Old Aug 17, 2003 | 11:28 AM
jbeamj's Avatar
did you change the "weight" of the oil such as went to 5w-30 or something like that
if not then a small drop in pressure like that could be normal and i dont see a problem with the numbers themselves as long as you have approx 4-5 lbs per 100rpm (gm specs for that) personally i prefer 10psi/1000rpm but your still within guidlines
Old Aug 17, 2003 | 11:40 AM
FastZinTennessee's Avatar
That looks fine. My car runs about 10-12 psi at hot idle. Even though I think that's kinda low, the pressure comes up nicely with RPM so as far as I can tell all is well.
John
Old Aug 17, 2003 | 12:28 PM
LeeS's Avatar
THanks Guys !
Anyone else out there!!!
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 05:48 AM
charchri4
Apr 14, 2015 06:40 PM
ad356
Apr 11, 2015 08:49 AM
jayblev95
Dec 1, 2014 06:55 AM
