.20 mill with 224 230
Old May 26, 2003 | 11:01 AM
z28ss9496's Avatar
Talking .20 mill with 224 230
I am helping my buddy change a cam in his car. He is going ahead and have his heads cleaned up and milled a little to help increase compression. We were wondering about valve clearance milled at .20 with the impala gaskets. He will be running a .503 .510 with 1.6's. I am pretty sure this will be ok. My ? is what compression will this give him and is it enough to bother with. oh yea this is a stock bottom end. What would you recommend
Thanks in advance
Old May 26, 2003 | 11:41 AM
Mindgame's Avatar
Re: .20 mill with 224 230
Thanks in advance
You meant .020 right?
.2 is a little better than 3/16 of an inch.
Milling the heads .020 won't cause a clearance problem but it wouldn't hurt to check either. A change to 1.6's and a .020 deck may require a valvetrain geometry correction (pushrod length change) but you'll have to get everything together and check it out.
As for compression, .020 is about 3ccs which gains you ~.4 point in compression. The .029 Impy gasket gains you another ~.2 points over using the stock gasket.
HTH
-Mindgame
Old May 26, 2003 | 12:48 PM
NightTrain66's Avatar
I agree with Miondgane, it never hurts to check but from what I have seen, they have ALOT of P/V clearance and even milled .030 and GM 847 cam has plenty of clearance on a stock bottom end.
NightTrain66
Old May 26, 2003 | 12:50 PM
oops, I meant "Mindgame".
bunker
Aug 21, 2015 10:21 AM
karpetcm
Aug 14, 2015 03:02 PM
MadMav
May 25, 2015 09:35 PM
phancom
Feb 3, 2003 04:38 PM
