2 weird things happening to my 95 ta
Old Feb 3, 2003 | 02:03 PM
JWA95TA's Avatar
Ok, I have a 1995 Trans Am with 47k miles on it. It is a 6 speed, and the only mods I have are CAI, TB bypass, and !CAGS.
Here are the two problems I have had with it.
I seem to have a sort of backfire at real high RPM. Here is how I found out. One day after I got back to the house I thought I would just hear it rev up, so I revved it, up twice , the 2nd time putting the RPMs right on the yellow, and I hear this pop sound, that sounds like kind of an explosion going through a pipe, like the exhaust manifold or my CAI.
Next day I am running it hard in first, RPMs up kinda high and POP same thing. Yesterday I was in 2nd (so I know I am not excellerating faster then the TACH can keep up, and before I get to the end of the yellow, POP! Now I had my car on a dyno 4 months ago and the tach was at the red, but no pop. I didnt even hit the rev limiter. And this doesnt sound like a rev limiter as I have heard people hit theres . This just sounds bad
The other problem, is if I am in like 3rd or 4th and going between 1500- 2000 RPM I seem to have this kind of bucking going on. Thing is, it only happens if I am at about 25% throttle. I give it more and it goes away. It kind of feels like picking up slack in the driveline, but I dont think that is it. And I know it didnt do that before.
Just hoping some of you guys might have had experiece with this or know what it could be.
Jason
Old Feb 3, 2003 | 02:07 PM
IDOXLR8's Avatar
I would say check your plugs, plug wires and Ignition COil.
Old Feb 3, 2003 | 02:46 PM
JWA95TA's Avatar
I know I had to replace the #1 plug after I broke it putting it back in after I decided to look at it . Is that a backfire I ma hearing then at high RPM? Is this effecting my low rpm bucking? (im just full of question arent I? )
Jason
Black94mula's Avatar
Everyone's gonna say Opti....which it may be, but i had the same low end bucking under low throttle as you. I changed the plugs and wires and its fine now. Funny thing too, because the last wire i pulled off was the coil wire and it was all corroded, so i'm almost positive it was just that. Good luck...
Old Feb 3, 2003 | 02:47 PM
NiteRider's Avatar
I say ignition coil to, it seems to be related with high rpm problems. Is it a stock coil or a MSD?
Old Feb 3, 2003 | 03:08 PM
JWA95TA's Avatar
It is the stock coil. That high RPM backfire sound sounded real bad yesterday, like I blew the engine or a head gasket
Thanks for the help. Tonight I will go make sure the coil wire is on good.
Jason
Old Feb 4, 2003 | 06:05 AM
IDOXLR8's Avatar
Typically high end missing is related to bad ignition coil and low end missing is related to bad opti.
Old Feb 4, 2003 | 08:53 AM
JWA95TA's Avatar
WOuld the low RPM missing be a missing or opti problem if it cleard up when I gave it a little more gas? This morning I was in first gear in the same rpm range and I didnt have a problem. Could it be like too much slack in the driveline too ??
jason
Dylan Latshaw
Mar 21, 2015 09:48 AM
97z28k&N
Jan 9, 2015 04:58 AM
Hal Fisher
Sep 14, 2002 09:36 PM
BLUESMAN
Aug 26, 2002 06:07 AM
guionM
14
Jun 19, 2002 08:30 AM
