2 parts iso-heet 1 part lucas = death
Old Mar 2, 2010 | 04:23 PM
  #16
Guest47904's Avatar
Guest
Originally Posted by bw_hunter
Actually, Iso-Heet is isopropyl alcohol, not methanol. Isopropyl is less harmful than methanol in fuel systems.....
http://www.imperialinc.com/msds0055120.shtml
No I'm sorry, it's methanol.
From the manufacturing website:
http://www.goldeagle.com/brands/heet/faq.aspx
HEET
Q: How does HEET work?
A: HEET contains special additives and methanol. When HEET is added to the gas tank, it sinks to the bottom and mixes with any water. Since both HEET and water are heavier than gasoline, they go to the bottom of the gas tank. HEET absorbs water and keeps it from freezing, and blocking the flow of gasoline through the gas line and fuel pump. When the vehicle is started, the additives, methanol, water, and gasoline are consumed during combustion inside the engine.
Q: How does Iso-HEET work?
A: Iso-HEET contains isopropanol and special additives including Fuel Injector Cleaner.
It has Isopropanol in it. But it's major constituent is METHANOL.
Old Mar 2, 2010 | 04:37 PM
  #17
maliveline's Avatar
turns out i had a coolant sensor go bad. the guy said it was reading -7 whatever that means and basically my engine was trying to use gas like it was cold all the time giving me about 8 miles to the gallon. anyway i dont really know why that happened at the exact time i added iso-heet
Old Mar 2, 2010 | 05:19 PM
  #18
bw_hunter's Avatar
HEET
Unfortunately, you selected the wrong product. The original, HEET, is methanol. The alternative, ISO-HEET, is isopropyl alcohol. Take a look at the MSDS and you'll see the ingredients for ISO-HEET....99% isopropanol or isopropyl alcohol (same thing). MSDS's are documents required by law for state reporting purposes. If it says Isopropanol then it is, regardless of what an FAQ might say.
In any case, this isn't worth arguing about. I won't be adding anything further
HectorM52
Jul 30, 2017 11:46 AM
novaiiman
May 15, 2016 11:36 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
IrocSS85
Jul 18, 2002 10:35 PM
