2 parts iso-heet 1 part lucas = death
Old Feb 24, 2010 | 02:53 PM
maliveline's Avatar
does anyone know if putting 2 bottles of iso-heet and one small bottle of lucas fuel injector cleaner will do permanent damage to a 93 z28
Old Feb 24, 2010 | 07:51 PM
maliveline's Avatar
i know it was a stupid thing to do
Old Feb 25, 2010 | 01:40 AM
maliveline's Avatar
please someone help
Old Feb 25, 2010 | 02:37 AM
juniorssrollin's Avatar
im not sure of an answer for you...but what or who gave you this brilliant idea?
Old Feb 25, 2010 | 05:04 AM
please someone help
PLEASE read this:
https://www.camaroz28.com/forums/lt1-based-engine-tech-9/all-members-read-abuse-%22ttt%22-5485/
Before you edited the first post you had a more complete description of the problems you encountered. By going back and deleting that info, you probably limited anyone's ability to respond. The don't even know what happened.
Old Feb 25, 2010 | 12:03 PM
maliveline's Avatar
i figured my first post was too long and thats why i wasn't getting any responses, oh well adding fresh gas seems to be helping but my car is still not back to where it was.
Old Feb 28, 2010 | 03:26 PM
maliveline's Avatar
I think I blew a head gasket
Old Feb 28, 2010 | 04:34 PM
bw_hunter's Avatar
What did you do with it? If you just added it to the tank I doubt it'll do anything permanent. The iso heet is just isopropyl alcohola dn you add it to remove waqter from fuel. It raises the octane but has relatively low energy content. The fuel injector cleaner is probably a blend of petroleum distilates and won't harm the engine.
If you blew the head geasket then something else was wrong......imho
Old Feb 28, 2010 | 05:26 PM
maliveline's Avatar
ya i just added it to the tank and then my car died and wouldn't start so i pumped half my gas out and refilled and thought it was getting better but it still sucks. im going to a mechanic on monday.
Old Mar 1, 2010 | 05:56 PM
69gto96z's Avatar
Why would you do this to begin with? I'm sure both labels say add to 15 gallons, if not more. So you doubled the strength of the iso-heat, then added more on top of it. Whatever happened probably is not permanent, but I would never do this again, and if someone told you to do it, I would never listen to another word of advice they have...
Old Mar 1, 2010 | 10:33 PM
maliveline's Avatar
ok to be honest im a recovering alcoholic and addict. so my brain is permanently wired like this.. " if one is good 2 is better, and if 2 is better than 1000 is great... this continues to infinity."
Old Mar 1, 2010 | 11:27 PM
bombebomb's Avatar
If this is your edited post, I'd love to see the original.
Next time though I recommend you read the bottles first at least.
Old Mar 2, 2010 | 05:22 AM
I don't see this going anywhere.
WHAT ARE THE SYMPTOMS YOU BELIEVE WERE CAUSED BY THIS FUEL TANK BLEND?
Unless you describe the problem you were trying to solve with all the additives, then detail the problems that you believe were caused by the additives, there's very little people can do to help you, other than ask why you did it?
How did you make the quantum leap from from some fuel tank additives to "I think I blew a head gasket"?
Old Mar 2, 2010 | 05:32 AM
Guest47904's Avatar
Guest
2 bottles of heet is not a problem. See this according to their website.
Q: How many bottles of HEET or Iso-HEET should I use at one time?
A: One bottle of HEET or Iso-HEET treats up to 20 gallons (75.7 L) of gasoline. You should not use more than 2 bottles in a 20-gallon (75.7 L) gas tank, 3 bottles in a 30-gallon (113.6 L) gas tank. HEET and Iso-HEET are safe to use in every tankful, in all seasons, all year-round.
So the heet itself was not the problem. The effect of the heet may have been.
Incidentally. This stuff is METHANOL. I've read somethings saying this stuff is a no no in cars. While I have read other things from the manufacturers of methanol products saying it is not harmful.
BUT NOWHERE DID I SEE ANYTHING WRITTEN THAT SAID IT WAS "HELPFUL".
One last note: The "if one is good more is better" thinking is not the result of being a recovering "anything". And the fact that you are recovering is great but it's TMI.
Old Mar 2, 2010 | 10:36 AM
bw_hunter's Avatar
Actually, Iso-Heet is isopropyl alcohol, not methanol. Isopropyl is less harmful than methanol in fuel systems.....
http://www.imperialinc.com/msds0055120.shtml
