1997 lt1 ewp timing chain options
Old May 4, 2012 | 06:24 PM
mou5e's Avatar
I have a 1997 z28, doing an electric water pump so I dont need the water pump drive.
can I use any small block chevy timing set?
what would I have to do to run a double roller set?
thanks
Old May 4, 2012 | 07:01 PM
96capricemgr's Avatar
Re: 1997 lt1 ewp timing chain options
What are you trying to accomplish with the new chain?
Old May 4, 2012 | 08:32 PM
mou5e's Avatar
h/c 355 maybe n2o some day, I would like a good single chain so I don"t have to modify the timing cover
Old May 4, 2012 | 09:41 PM
Why do you need anything other than stock?
Old May 5, 2012 | 11:03 AM
mou5e's Avatar
stock one has 175k on it and is worn.
Old May 5, 2012 | 12:33 PM
DirtyDaveW's Avatar
I think Dwayne is indicating that for your goals and ease of use/installation, you should probably just get a stock replacement timing set.
I have the Cloyes true roller double chain. I had to modify(more exactly, grind the hell out of it) the timing cover and ditch the misfire reluctor and use a shorter yoke. That was all for a solid roller cam over .600 lift. With my current setup(low lift turbo cam), I could use a stock timing set and be fine.
Old May 5, 2012 | 12:45 PM
mou5e's Avatar
would a single roller set for a sbc work without much work?
Old May 5, 2012 | 04:55 PM
DirtyDaveW's Avatar
The nose of the cam is quite different when comparing an LT1 and a traditional SBC. I don't think you could just request a SBC timing set and it work with an LT1 cam nose.
Well, I did a quick search and perhaps I am wrong. Read this...
http://ls1tech.com/forums/lt1-lt4-mo...g-chain-2.html
Old May 5, 2012 | 05:24 PM
bw_hunter's Avatar
Cloyes 3145 is a dual row chain and requires some clearancing of the timing cover. I run one and the clearancing was minimal. 3157 is a single row chan and might not need clearancing...
I went this route when I changed over to the 95+ opti and was deleting the cam driven waterpump. It works just fine....
Old May 5, 2012 | 06:10 PM
How does that work with the 96-7 CPS???
Far as "worn" I would worry more about your new electric waterpump than I would the 175K mile timing chain
Old May 8, 2012 | 02:56 AM
rat's nest Z-28's Avatar
I went with the Cloyes 3157 & needed no clearancing. Cloyes claims that the double roller has no strength advantage over the single roller. I also knocked out the water pump drive from the engine block & welded up the hole in the timing cover before installation of the single roller timing chain set...
Old May 8, 2012 | 05:21 AM
bw_hunter's Avatar
Cloyes claim is ridiculous on its' face...of course a double row chain is stronger than a single row chain. That said, and I suppose this is their point, either the single row or double row chain is much stronger than absolutely needed....
Old May 8, 2012 | 06:40 AM
https://www.camaroz28.com/forums/lt1...t-fail-521308/
Since that thread I helped a friend put together a daily driver with a .590 lift cam and stock waterpump, just put a Cloyes S505 lower gear on to tighten the chain, been fine for a couple years now.
Old May 8, 2012 | 07:44 AM
DirtyDaveW's Avatar
So with the Cloyes 3157, is there still room for the 96+ Crank Position Sensors reluctor?
Old May 9, 2012 | 03:22 PM
Anyone wonder why the single roller timing set costs $15 dollars more than the double roller timing set? I sometimes wonder because the single roller chain is like a motorcycle chain with motorcycle sprokets/teeth & the double roller chain is like two bicycle chains with bicycle sprokets/teeth. The double roller is probably stronger but I sometimes wonder if it really is...someone should do somekind of load test & put all the debate to rest...
oldschool
Feb 9, 2016 09:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
