Craigslist LT1 top-end (part 1)
Old Feb 25, 2013 | 11:04 AM
BMX Dad's Avatar
Over the years I have bought most of my bolt-on upgrades, including brand new wheels and tires, (see signature) on Craigslist for dirt cheap.
I started collecting pieces for my top end build on my 134K (not hard) miles LT1 Z28.
Goals:
• 300 + hp at the wheels
• Fix oil leaks in the front of the motor
• Pass CA smog – Very clean now with a brand new OEM single cat - original owner bought new in 2009 and never installed it.
• Keep daily driver / weekend cruiser quality
• Do it on the cheap (buy new where I need to)
Bought OEM AL heads, cam, and intake on CL for $180 and dropped them off at my machine shop for porting, valve job, matching ported intake, and custom ground cam. No hurry on shop work since originals are still on car. Will post flow numbers in a couple of weeks.
Upgrade plans for top end:
• Custom grind cam (224/224 .525/.525 lsa112)
• New Comp cam 1.6 NSA roller rockers
• New Spring set, seals, and hardened 7.2 pushrods from Alex Parts
• New GM guide plates
• New 7/16 posts
• 30lbs injectors ?? See below
Other new stuff:
• Harmonic balancer
• Water pump
• Timing chain set
• Front end oil seals
• Gaskets
• Tune
Questions:
• Do I need a 52mm TB or will stock be adequate?
• Can the OEM TB be bored out to 52mm
• Do I need the 30 lbs (or higher) injectors?
• Do I need a new opti? (Mine is a 2yr old GM part)
• Are stock head bolts OK?
• Do I need to buy new push rods? (I have read that the stock rods are hardened)
• What am I forgetting?
Old Feb 25, 2013 | 05:49 PM
Kevin Blown 95 TA's Avatar
Re: Craigslist LT1 top-end (part 1)
Goals:
• New 7/16 posts
Other new stuff:
• Harmonic balancer
• Water pump
• Timing chain set
• Gaskets
• Tune
Questions:
I'll take a stab at it
• Do I need a 52mm TB or will stock be adequate? - Stock will be OK, but 52 wouldn't hurt anything
• Can the OEM TB be bored out to 52mm - Yeah, there are places that can do that
• Do I need the 30 lbs (or higher) injectors? - 30# would be fine for that build
• Do I need a new opti? (Mine is a 2yr old GM part) - I'd say no
• Are stock head bolts OK? Get new ones. Yours aren't TTY, but still they are old and tired
• Do I need to buy new push rods? (I have read that the stock rods are hardened) - Yours should be fine, but always check they are the right length for your new parts
• What am I forgetting? - I'd say research the GM guide plates - I remember lots of discussion about them not lining up correctly for other builders, but I can't remember the details. You don't need NSA rockers with that lift, but that's up to you (if you upgrade the cam later, then you'll already have the correct parts)
Old Feb 25, 2013 | 07:15 PM
ACE1252's Avatar
Get trickflow guideplates. The GM ones have issues with not being properly heat treated(mine had the same problem).
I had this problem with the GM ones....
https://www.camaroz28.com/forums/lt1...eplace-769144/
I think the number for the trickflow guideplates is....
TFS 30400623-8
Old Feb 25, 2013 | 08:19 PM
BMX Dad's Avatar
Excellent.
Thank you for the advice.
Old Feb 26, 2013 | 01:51 PM
BMX Dad's Avatar
Now going with a 224/230 .525/.525 112lsa cam
Old Feb 26, 2013 | 02:03 PM
ACE1252's Avatar
On the pushrods, if I recall correctly, some years were not hardened for guideplate use. I got a set of Comp Cams Magnum pushrods 7.2"(CCA-7608-16).
Old Mar 4, 2013 | 10:01 PM
BMX Dad's Avatar
After more research and advice from my tuner, I am now going with a 114 LSA cam so I do not run into problems passing smog.
Old Mar 5, 2013 | 12:11 PM
KW Baraka's Avatar
With that cam......unless the plan to hit 6.5K RPMs regularly, I'd go with 3/8" studs, self-aligned roller rockers and no guideplates.
But.....that's just me .....
And if your tuner says go with 114* LSA in order to make smog, then I'd say......"look for a better tuner".
KW
rockync7
Jan 1, 2015 05:10 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
