1994 m6 starting trouble
Old Dec 23, 2013 | 05:36 PM
jasonspd's Avatar
This camaro is giving me a headache. 1994 camaro m6. 120,000 miles. I've owned it since 1996. Basically stock. Replaced opti twice over the years. Water pump. Put a resistor in to bypass the security system last year. After that it randomly died twice and was stationary this summer. I checked and it was getting no fuel. I changed the entire pump assembly. It started right up. After 5 minutes it died. Started back up. Drove it to work and it randomly dies twice. Did some research and changed the ICM and coil Saturday. Car ran great. After 5 starts I took it to the local hardware store and upon coming out to leave it won't start. No fire. The security system light goes out after a few seconds and doesn't flash or stay on. Fuel pump is running. I have a scanner. No codes at all. I'm absolutely stumped. Any ideas? Anyone had this happen before? Thanks in advance. Jason
Old Dec 24, 2013 | 08:49 AM
Re: 1994 m6 starting trouble
Start with the opti diagnosis sticky at the top of the forum.
Old Dec 31, 2013 | 08:50 PM
SuperSportSS's Avatar
My 93 was doing the same thing. I had some corrosion built up in my opti and I took some steel wool and cleaned all metal contacts and sealed everything back up with silicone and haven't had a problem since. And my opti has over 200k on it
Red Hawk 94
Mar 18, 2019 04:03 PM
Noenav
Mar 1, 2019 07:38 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
David Dorris
Jan 17, 2015 08:10 PM
