Attention lt1 single plane guru!!
Old Jul 18, 2013 | 10:55 PM
stockssn2o's Avatar
Basically the question at hand is will a pulse width modulated iacv work on an lt1? I know the factory one is a stepper motor..
Trying to make edelbrock 39783 TB work with the factory computer..
Do I need to change iacv or just get a different throttle body?
Old Jul 19, 2013 | 02:17 PM
stockssn2o's Avatar
Re: Attention lt1 single plane guru!!
Well to answer my own question
This throttle body won't work with a factory computer
Old Jul 19, 2013 | 06:42 PM
97WS6SCharged's Avatar
If you're not set on that particular style of TB you could see if Aaron over at 6061.com could build an elbow for an LTx style throttle body. I have one of his LSx elbows and it's an awesome piece.
Old Jan 1, 2014 | 02:35 PM
rustedlt1's Avatar
I know this is an old thread but is the newer tb you wanted to.use similar to the lsx type of throttle body if so , if one were running a 0411 pcm swap im sure you can run a newer style IAC.
Collector Car
Jan 5, 2015 10:58 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
Elcojoe
Nov 17, 2014 10:27 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
