Going to do timing chain, i got the cloys single heavy duty timing chain from jegs. The gaskets on the timing cover (all) a new jegs optispark,. Was wondering how i get the hub off the crank properly and back on?
94 has the center spline driven opti which needs the corresponding splined cam gear, make sure that's what you have. Removal use a puller it works good, be sure not to press against the crank threads. Install use 7/16 x 20 threaded rod and pull it on.
Post a link to the timing set you got. If it does not have the spline drive cam gear, it's not going to work (if you still have the stock, non-vented opti).
Timing chain is a Cloys Cloyes Heavy-Duty Timing Sets CLO-C-3228
Timing Chain and Gears, Link Belt, Steel Sprockets, Chevy, 5.7L LT, Kit from summit racing.
Ok, well i also read that i have to take the oil pan down in the front a bit, i remember now the last time that i did this the gasket broke, and i have no way to replace that because im in the driveway, i may now have to just replace the opti instead of do the whole job right. Thank you again guys for all the help, this car is gonna be nice and hopefully be fun to drive when its all done again.
