1994 Camaro V6 swap to LT1 - Need LT1 help
Old Apr 24, 2013 | 07:14 PM
hambrightrandy's Avatar
I have a 94 Camaro that I just dropped a lt1 in it. Saturday I got it to run for about 3 mins and now I cant get it to run. just put new fuel pump in it last night and I have 44 psi and car still wont start. so if anyone can help it wood b nice?
Old Apr 25, 2013 | 04:21 PM
Re: 1994 camaro v6 swap to lt1 help
Welcome to CamaroZ28.com!!
New Member Intro isn't the best forum to get tech help. Since you've already done the swap and are trying to get the LT1 engine to run, let's copy this thread to "LT1 Based Engine Tech".
Old Apr 25, 2013 | 04:44 PM
Re: 1994 Camaro V6 swap to LT1 - Need LT1 help
To get started on helping you:
What year is the LT1 engine, PCM and harness?
Have you scanned it for codes?
Have you checked for spark - at the coil? ..... at the plugs?
Old Apr 25, 2013 | 05:07 PM
The lt1 is a 94 caprice , the pcm 94 capricw and harness is a 94 Camaro harness
Old Apr 25, 2013 | 05:09 PM
I have spark at coil,and plug
Old Apr 27, 2013 | 08:04 AM
Thirim's Avatar
all your sensors plugged in? Air temp sensor on the intake elbow would keep it from starting easily.. Check for a blown fuse to the PCM. If I recall, there are 2 wires for the PCM to provide 12V..
Old Apr 27, 2013 | 12:14 PM
I will double check thanks
Old Apr 27, 2013 | 01:05 PM
You indicate you have 44psi fuel pressure. Since the engine is not running, I assume that is the pressure the pump primes to. Check the harness connector for the Optispark distributor. If that's loose, corroded, or has a bent pin, it can set DTC 16, which shuts down the fuel system and prevents the engine from starting or running. Scanning it would turn up any codes, like DTC 42 for the white wire to the IC Module, which can also prevent it from starting.
The IAT sensor doesn't really affect much of anything on an MAF setup (94-97)... not like it would in speed-density (93). Should not make it harder to start. Coolant temp sensor is more likely to be a problem in that respect.
Old Apr 27, 2013 | 08:27 PM
just looked at the harness it ok , I have a key that plugs in under the dash but win I plug it in the s/engine light wont flash. maybe my pcm is no good? but I went out and got that new coolant temp sensor and nothing. but now the car backfires.
Old Apr 27, 2013 | 11:42 PM
You indicate you have a 94 PCM. You can't flash the codes on the SES light by shorting the ALDL pins (which is what the "key" does). The last year that worked was 1993. You need a "real" OBD-I scanner, or scanning software like TTS DataMaster.
Old Apr 28, 2013 | 08:42 AM
ok thanks I see if I can find one.
Old Apr 28, 2013 | 11:23 AM
so just went out and got obd-1 scanner and my car wont scan no codes. maybe its the harness?
Old Apr 28, 2013 | 02:09 PM
Was your "scanner" an Actron 9001, that cost $30? If so, all that does is short the ALDL pins, and as already explained, that will not work. Actually says it will work with 94, but that's wrong. Or did you get a combination OBD-I/OBD-II scanner? They can have problems with setting up the correct engine info in OBD-I mode, or they can be looking for +12V in the ALDL connector, and there is none.
Old May 6, 2013 | 04:09 PM
went yesterday and got a new opt and car fired right up. now car sounds like its nocking
? will the ac pump do that if the hose not hocked up?
Old May 6, 2013 | 05:14 PM
The A/C compressor (your "pump"?) shouldn't even operate if the A/C system is not fully charged. The PCM monitors the system pressure, and knows there is none = A/C clutch does not engage.
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
dreamer1q
Jul 24, 2002 04:39 PM
dreamer1q
Jul 9, 2002 05:37 PM
dreamer1q
Jul 8, 2002 08:47 PM
