Steam Pipe behind heads
Old May 6, 2013 | 10:28 PM
94arcticwhiteM6's Avatar
I saw that there is a different part number for the 93-94 and 95-97, anyone know what the differences are? Are the bolts the same? Can you use the newer one on a 94 LT1?
Old May 7, 2013 | 05:09 AM
RamAir95TA's Avatar
Re: Steam Pipe behind heads
They should all be the same.
Old May 7, 2013 | 07:02 AM
The early steam line has a hose attached to the end that goes to the radiator. That is the only difference. You should be able to use the later steam line as long as you reuse that hose (or put a new one on).
HectorM52
Jul 30, 2017 11:46 AM
MadMav
Feb 6, 2015 11:02 PM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
