1993 lt1
Old Jul 2, 2008 | 05:54 PM
strokerz28's Avatar
1993 lt1
How good is a 1993 lt1 out of a firebird how are the in comparison to a 1996 lt1 in a z28 as far as power will i notice a diffrence for i am putting one in my 96 z28
Old Jul 2, 2008 | 06:00 PM
Basically the same engine as far as the block and internals, but you will need to swap over parts from your 96 like the intake manifold, fuel rails, injectors, timing cover with CKP sensor, vented Opti, oil pressure sensor, and knock sensor. To do the vented Opti swap, you need to swap the timing set and the cam from your 96.
Old Jul 2, 2008 | 08:00 PM
strokerz28's Avatar
do you have to do the cam swap
Old Jul 2, 2008 | 10:27 PM
If your 93 engine has the stock cam and you are going to use the vented opti setup from the later engine, yes.
jb4xx
Feb 2, 2015 10:00 PM
camy 1993
Feb 1, 2015 07:16 PM
Sarahrope64
Nov 27, 2014 11:17 AM
cASe SenSiTive
Sep 1, 2002 02:37 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
