rods and pistons for LE heads and cam
I wanted to beef up my shortblock while it's out of the car getting new rings and bearings so what would you guys recommend for le1 heads and le1.6cam?
I beam or H beam forge rods? 5.7" or 6.0" stroke?
forged pistons? what brands?
stock compression or close to it
To the thread starter, what do you plan on doing with the car? Spraying or just normal NA use?
If you're going to remain N/A then stock rods/pistons will work just fine.
cheapest way out for a 6400 RPM N/A engine is to reuse stock rods with good ARP bolts, stock crank and some of the TRW L 2256 pistons (.030 over). The stock pistons are WAY down in the hole and that kills compression and quench. If you have the budget, get some aftermarket pistons and just focus on good machine work.
It will live at that RPM and HP level forever.
Focus on quench and compression. measure the deck ht once it is all back together and use a head gasket that gives you a .030-.035 quench. Probably gonna need some .026" Mr Gasket 5716 heads gaskets to get there assuming the piston ends up .004-.010 in the hole at TDC.
Lloyd Elliott
972-617-5671
Elliottsportworks.com
Lloyd Elliott
972-617-5671
yep, here ya go. . . . . . .
http://store.summitracing.com/partde...0&autoview=sku
Lloyd Elliott
972-617-5671
Lloyd Elliott
972-617-5671
