1993 lt1
Basically the same engine as far as the block and internals, but you will need to swap over parts from your 96 like the intake manifold, fuel rails, injectors, timing cover with CKP sensor, vented Opti, oil pressure sensor, and knock sensor. To do the vented Opti swap, you need to swap the timing set and the cam from your 96.
jb4xx
Feb 2, 2015 10:00 PM
Sarahrope64
Nov 27, 2014 11:17 AM
