160 Thermostat
Old Jun 29, 2008 | 09:39 PM
SpeedinZ's Avatar
160 Thermostat
I know this is probably a dumb question but does replacing the stock thermostat with the 160 help on gas mileage or give me any more power?
Old Jun 29, 2008 | 11:00 PM
95Blackhawk's Avatar
160 does not itself give more HP. It gives the ability adjust timing that may offer more HP. I personally like to run my car cooler.
Old Jun 29, 2008 | 11:39 PM
GM set the operating temp on the LT1 (and most of its other engines) high to maximize fuel economy, and minimize emissions. Lowering the operating temperature may result in less complete combustion, increasing emissions and reducing fuel mileage. Not likely you would notice the loss of fuel economy though.
Lowering the coolant temp reduces the thermal efficiency of the engine, reducing power. However, that loss can be offset by the reduction in the temperature of the intake air charge, and the ability to run a degree or two of additional timing. And, if you don't change the fan on/off temps in the PCM, the 160* t'stat is only going to make it run cooler at freeway speeds, not in heavy traffic or at idle.
Old Jun 30, 2008 | 12:21 AM
SpeedinZ's Avatar
So I should get the fans tuned to come on sooner as well? Thanks a bunch I'm glad I didn't get laughed at.
Old Jun 30, 2008 | 01:30 AM
6SpdLT1Z's Avatar
Yeah typically you would tune the fans to kick on earlier with a lower thermostat, or buy/build a fan switch.
I've got a hypertech 160* stat for a LT1 if you want it. You can special order them through AutoZone for $25ish. I'll let you have mine (brand new) for $20. I'm in Overland Park, KS
G-BODYT56
Jan 14, 2022 11:14 PM
Jeff1904
Jun 5, 2016 05:00 PM
chevy94c
Mar 26, 2016 08:53 AM
Bobczar
Oct 23, 2015 11:22 AM
MikeWhitener
Aug 2, 2015 06:17 PM
