160 stat fan temp recommendations?
Old Jan 28, 2004 | 05:49 PM
Joe K. 96 Zeee!!'s Avatar
Getting some reprogramming done. I have a 160 stat installed. I used to have the fans come on at 185 or so and I think it was 195 for highspeed. Problem with that is that in the summer whenever I stop the fans are coming on. I'm going to have this car for at least a few more years and I don't want them wearing out prematurely. I still want a little spark advance advantage though.
I was thinking about going with the following...
Fan 1 on/off at: 190°F/180°F
Fan 2 on/off at: 200°F/190°F
Any comments/recommendations??
Old Jan 29, 2004 | 12:53 PM
mebanditws6's Avatar
If you're concerned with fan life, bump each of those temps up another 10 degrees. That should keep the motor from detonating on all but the hottest of days (even then it'd be at a minimum). I'd concentrate on keeping the radiator clean with annual flushes, and ALWAYS make sure it's bled. Every oil change or sooner (if it's running hotter while driving) bleed the system. If you want some advance the last thing you need are hot spots from air bubbles in the cooling system.
Jason
Old Jan 29, 2004 | 06:35 PM
kaoticcamaross's Avatar
Well I have had mine run at 160 degrees with my 160 thermo and they have lasted 2 years.
Old Jan 29, 2004 | 07:38 PM
Eliminator's Avatar
If the fans wear out theres tons of f-bodies in the junkyard just get the fans off them. I have a 1987 Motorcycle and wired my fan to turn on when its on and it never burned out yet.
Old Jan 29, 2004 | 07:46 PM
97FormulaWS-6's Avatar
I've got mine at 176/178, with the hystersis @ 5...
Old Jan 29, 2004 | 07:55 PM
Spinner's Avatar
200/210 with a manual fanswitch. Def. bleed the coolant
Old Jan 29, 2004 | 08:09 PM
200/210 sounds good. I almost forgot about doing a manual fan switch, thanks spinner!
Old Jan 29, 2004 | 08:12 PM
ny_z28man's Avatar
looks fine where your fans are now.....
Rich_z28
Sep 13, 2002 03:35 PM
Rich_z28
Sep 8, 2002 12:00 AM
Rich_z28
Aug 29, 2002 11:01 PM
Rich_z28
Aug 29, 2002 10:44 PM
Rich_z28
Aug 27, 2002 12:20 AM
